dev997
Sprint LG Optimus G with Reliance CDMA
Hello gurus !!!
First of all , HAPPY NEW YR TO ALL RIMWEBians !!!!
I've been thinking of getting the latest superphone Sprint branded LG optimus G from US.
I wanted to know if anyone of our estimated gurus have already got their hands on it and flashed it with RCDMA service ?
If yes, is it a simple straightforward process or are there any complications ?
As it has a qualcomm chipset, I'm pretty positive that flashing radio shouldn't be an issues, but just wanted to confirm before buying !
Cheers
Dev
Somebody's profile on Rimweb has LG Optimus G listed as the phone they are using.. I just can't remember who..
Sent from my SPH-D700 using Tapatalk 2
  On 1/3/2013 at 11:35 AM, astrokidvaibhav said:
Somebody's profile on Rimweb has LG Optimus G listed as the phone they are using.. I just can't remember who.. Sent from my SPH-D700 using Tapatalk 2
OK.. that would mean this phone can be flashed with RCDMA.
Can someone please confirm this so that I can buy one ..
Cheers
I am using the phone. You can go for it definitely. Very smooth with good look and smooth ui.
Sent from LG Optimus G
  On 1/4/2013 at 2:49 AM, Praveen sinha said:
I am using the phone. You can go for it definitely. Very smooth with good look and smooth ui. Sent from LG Optimus G
Thanks mate !!! I'll get this piece of beauty asap..
Cheers
Awesome phone, getting superb battery backup as well for my usage. :D4xp.png
Ankur which kernel u using?
The one in lifeless v14?
Dear friends,
I recently bought LG OG LS970 from Tarun Kabra ji.
I want to share here my immediate observation about this handset as below---
+Positive things as per me:
+ It's very smooth in touch as well as quick in operations with 2 gb RAM and 32 gb Internal Memory
+ It's really slim, compact and light for the given 4.7 inches display
+ Having less number of inbuilt apps
+ Default SMS app is capable of sending group sms for Upto 40 contacts at a time
+ Quick memo function available which I find a unique way of noting down on call info and putting some text on photos, pictures etc
+ File Sharing function seems good thru wifi (though I have not utilised it so far)
+ Display brightness it's good even at 50% Brightness level
-Improvement areas as per me:
- Camera flash Auto function does not perform the way it should be. Also the camera quality is not upto the mark for 13 mp camera
- Any picture seen by zooming is really disappointing in terms of sharpness quality of the picture
- My handset is getting hot when continuously used online
- Not able to update it above OS 4.1.2, every time I got error when tried
- For me battery does not last for the day when data connection is always on
Friends please share your views and also suggest solutions (if any) for my improvement area issues.
Regards,
Sadanand
Sent from my LG-LS970 using Tapatalk
I am using this phone. it is very delicate handset just dropped two or three times and back glass broken in pieces. The front lower screen also broken and navigation keys are not working. Using it only through Pie.
The camera is total disappointment, it is worse than galaxy nexus 5 MP.
this one also GSM can be unlocked permanent if anyone wants :)
Could you please show which apps are install and which ones are set to syn all the time :)
Where is sim slot in ls970?
Sent from my VS980 4G using Tapatalk
Does Sprint LG OG has sim card slot?!!, it has some kind of embedded sim like HTC EVO 4G LTE AFAIK!!, wondering how it can be unlocked or used for GSM with out sim slot.... Am I missing something here?
Sorry my bad mistook it for a diff model
Sent from my LG-LS980 using Tapatalk
There is strange things happening with my LG OG. Suddenly the display with Small Square Black Spot appears and the handset again gets normal when I touch the screen.
Please see the enclosed screen shot and guide why its happening...
did u try to reset..does this happens everytime or does it only happen when it gets hot.
It happens very often, nothing specific as when phone gets hot or so.
I have not tried resetting phone as it is not creating any problem to me as of now.
its better to use in the way its working without creating any trouble for normal use.
I have observed something strange since last week. My handset shows more speed of upload than download when connected thru wifi.
Please see the below screen shot---
Can someone tell me why it is so...
Thanks in advance.
Regards,
Sadanand
Hi All,
Wanted to know if our beloved LS970 aka sprint optimus G works with reliance evdo rev b.
Of anyone has done I will be grateful to know and follow the method,
Thanks.
Lg LS-970 Optimus G Help Required...
Hello Friends...
I thought a weird problem with my phone. I think somebody can help.
I purchased the handset and got it activated on reliance cdma from a guy on ebay.
Recently my mobile got an system error which deleted the complete setting and spn number.
I contacted the guy in lg service centre which helped by restoring the roms on it.
Now I am getting reliance network on my handset but unable to make call.
I tried contacting the guy on ebay but he is not responding.
As per the recentpost on rimweb, I observed that new imported mobile cannot be activated on reliance cdma.
My handset is already activated.....
Can anybody please help me by restoring the earlier stting on my handset.
You need to reprogram the device. After that it will work.
  On 11/1/2014 at 1:55 PM, Maulik.Parekh said:
Hi All,
Thanks.
Any help on this .. anybody please .. since Mumbai has EvDO RevB i want to use it on LG OG LS970.
