omitav
BlackBerry 8130 - *228 says call failed
Hi gurus's, I need some help with a phone that i'm trying to get working. It's a BB 8130, flashed from sprint to ril, ril prl loaded, meid is also registered with ril now. the phone sees the network and i get a good signal. but the moment i dial *228 it says call failed but if i dial *225 then i get the relaince message asking me to contact cust care for resuming service. is this normal?
i went to the web world and they told me that they cannot activate the handset since *228 is not working :-(
what do i need to do to get this working? any help is highly appreciated!
Try *228001
Sent from LG Optimus G
Just tried that but same result - call failed :-(
IT happiness most of time - best is to manually enter MIN
##SPC - send and then edit MIN 2nd on the row
Thanks Genius, I got a new MIN and did ##spc on the phone, the first line is mdn so I put the mobile number there' while the second line is IMSI. What should I put there?
Imsi means MIN no so enter min in that row
MIN Number U have?
Activate the phone on another Mobile and get MIn and put it on second place
oops sorry, i meant that I got an MDN number and put that there.
but that is a good idea - to activate on another handset and use the min here. let me try that.
and just to make sure - I need to put the MIN number in the IMSI field? (that's what the second line says on the BB)
Edited by omitav
lotsa konfujion...
Sent from my GT-P5100 using Tapatalk 2
^^^ seriously confusing!
<blockquote class='ipsBlockquote'data-author="Praveen sinha" data-cid="284954" data-time="1359822438"><p>
Imsi means MIN no so enter min in that row<br />
<br />
Sent from LG Optimus G</p></blockquote>
Understood. Thank u :-). Working on pulling the min from another handset now.
Here's my update (hope it's not as confusing as my earlier posts :-)) - i tried activating my new MDN from 3 different phones (2030, 3100 and a 2340) and neither of them worked - after dialing *228, i can only get as far as the language selection. After selecting language i get the "your phone cannot be activated" message :-(
Can any kind soul guide on on how to get the MIN number please? Long story short - I have a new MDN but it just won't activate on any handset that I have. If there's any other way to activate a LG2030 that I have (apart from *228 or *228001) then I could take it from there.
