deepaksbz
Data Service Settings for Samsung Ace Duos GSM (Reliance GSM)
HI,
I am using Reliance GSM/CDMA Samsung Ace Duos handset. My connection is Reliance GSM and CDMA slot is let blank (prepaid)
My data services is not working in GSM. WiFi is working fine.
I sent an sms to Reliance with string ALL to 55100 but the settings was not received to save them
Below is my mobile settings for your information. Please help as how to make data work on this handset with GSM. I have taken the 99 rupees pack also.
Settings - Wireless and network settings - mobile networks (set options for roaming, networks, APN's)
- CDMA and GSM (tabs)
in CDMA
(where the below in not highlighting as the sim is GSM)
Use packget data (activate data network)
data roaming
(connect to data services when roaming)
Access point names
OMH - default
New access point
Name
PPP Digit
User name
Password
Authentication type
proxy
port
data bearer
mcc
mnc
Second Tab (GSM)
Network operators
(select a network operator) this is the only option for GSM
when clicked, the we have to select automatic or any operator, in my case it is reliance.
But the impt point i have to ask is when my mobile internet works in wifi mode, then it should work in data mode as well.
Another option in Network is
VPN Settings (set up and manage virtual private networks)
in CDMA
data roaming
Access point names
OMH - default
New access point
Name
PPP Digit
User name
Password
Authentication type
proxy
port
data bearer
mcc
mnc
Second Tab (GSM)
Network operators
In your set data will work only through cdma sim. The handset supports only r connect not gprs.
Sent from LG Optimus G
Get internet settings from reliance website and enter manually in your phone. Then you are good to go.
Thanks for your reply. You mean to say in this dual handset, with only GSM sim, data will not work... and data will work only on CDMA sim..
Thanks for the reply. Where in the website can we get the settings.
what praveen said is correct, get a seprate rel cdma sim and recharge with 94 u ll get 1gb data per month.
And that 94 recharge will give you 3g speed on evdo.. That too for 6 months.. And for your settings just google reliance internet setting profile and you will.get it..
No need to google or enter internet settings. Just insert an OMH cdma sim and it will itself make an apn named OMH and thats all.
