gourav343
Settings Messed up in Motorola Droid A855
While flashing my Droid a855 for reliance i accidently choose wrong reliance.nam file(the nam file i choose was one of my ruim card which i saved earlier). now i dont have any signal on my phone. when i goto setting >> about phone it shows nothing everything is blank like meid, min, mdn etc.
it is struck on aeroplane mode not allowing me to turn it off. since i cant turn on my radio i think i wont able to connect it to any port. i cant edit manually because now it si not accepting default spc code i.e. 000000.is there is an alternate way to connect it to cdma workshop.
things i tried
1. restoring factory setting.(as expected did nothing)
2. downgrading from cwm to custom rom.
3.connecting with virtal port.
i tried getting spc from ruim card using bitpim. incerted my sim in lg rd 3540 and and search in nvm folder but there was no nvm/security folder
now i am stuck on aeroplane mode for forever.
please help me or explain so that other member can get enifit from my thread
u need to revert to complete stock to overcome this issue. if u r unable to get through the spc code then flashing from sbf method shud get u back to complete stock settings. There is froyo sbf available on net, use rsd lite to flash it in bootloader mode. but u will have to reprogramm ur handset after doing this.
Thanks for replying dipesh bhai.i already tried that with froyo 2.2.sbf file with no success.currently i am on stock froyo2.2 and has noticed a strange problem
i cant do factory reset data in recovery mode.i dont know why but for some reason factory reset process failed every time.
Had u installed any recovery? Ideally in these case doing a sbf flash shud solve as it does a complete restore
Sent from my DROID RAZR using Tapatalk 2
Thanks dipesh bhai i got it working by flashing redlite but with different rom.this time i used this rom MILER_X1_00260_MILER_CDMA_BP_0.sbf.(this is stock rom 2.1 i guess)
after flasing my phone is back to normal.can you tell me how to transfer a ruim card no. on it. as there is no HCC available in my area
