arnuld
Unlocked CDMA Handset suggestion
I plan to use my TATA DOCOMO CDMA number on an unlocked CDMA handset, one of these two actually:
http://tinyurl.com/bjas2ps
http://tinyurl.com/aqy68nh
I want to use the phone primarily for calling and messaging only. No internet usage or apps playing. I just want to use a good touchscreen phone at around price 6-7K. I want to know what problems one faces when he uses unmatched/incompatible CDMA operator and unlocked handsets.
as I tested both,
351 - alcatel made - poor battery, hangs frequently, front camera
352 - zte made, battry is good, no hang during my use, no front cam
352 is priced for Rs 1000 more than 351
i still prefer mts mtag 3.1 aka huawei c8511 over these two..
triggered from tappa-talk # 2
Okay guys, I take your suggestion and put 351 out of selection. I do not need front cam as I am not gonna use internet/apps. So I am left with 352 and 3.1 . Aalok di you mean this by 3.1: http://tinyurl.com/b4hn6m8
That one seems good for me except that it has 2.8 inch screen, I found it very difficult to type an SMS even on Galaxy Y 3 inch screen. Hence I was looking for 3.5 or 4 inch screen. Any suggestions ? I see Pantech Breakout: http://tinyurl.com/adtc36z
Edited by arnuld
Instead of using those MTag phones, The OP may go for something like this.
Awesome Value For Money For Specs Offered.
Ask if any sellers have it or can bring it.
:previous:
Rajan Bhai this phone looks good is it unlocked or do we need to unlock it and does it need programming to be used in Reliance or Tata
@rajanmehta
Thanks Rajan but I wanted a Bar touchscreen only. No sliders or flip-open phones.
yes, i meant that only..
through i rarely use this handset now (only when i wanted to use TATA Indicom CDMA EVDO on PC via WiFi Tethering :P)
sold some 50 unlocked handsets till date, no one came back with any problem..
I see it is 2.8 inches touchscreen. Is this size enough for typing SMSs ? I type somewhere around 20-30 SMSs a day,, will I be comfortable doinh that on this small screen. Everything else seems fine to me for purchasing this phone.
As fo March 10, I am using MTS Mtag 352. It is Android CDMA. Screen size is no problem because I have installed MessagEase keyboard app. I came to know somehow I am not a fan of phones with shiny-god-like-features
Edited by arnuld
