commonman
Need help using TP-Link MR3020 with MTS ZTE AC2766
I have recently got a TP-Link MR3020 3G/4G router. I tried to connect my existing MTS ZTE AC2766 through it.
The modem setup already had the option for connecting to MTS with user-id & password and I have selected and saved them.
But even after stting this, first the router is taking ages to detect the modem and even after detecting it is not connecting. It displays "connecting.." but never connects.
Cane anyone pelase help.
Same victim here...yesterday received TP LINK 3040 Model....not able to connect with my zts reliance netconnect modem...Even Modem's Model is supported by TP Link....
Please try entering the details manually , like username , pass and dial number ... it should connect
Thanos for the help. Finally managed to get through to their customer care number. Apparently the toll free number works only from mobile. Seems the problem is witj the firmwire. The latest firmware has this problem. Thecustomer care guy noted the problem and mailed me the earlier firmware and mts data settings. On updating the firmware now the modem and router is working fine<br />
Edited by commonman
^^^ can u mail me the firmware link...Thanks in advance.
@Sreejith... I already tried but doesnt work.
His model is MR3020 while Yours is 3040. Model is different. Don't use his model firmware or you may mess up the device.
You can download the firmware for 3040 from here >> http://www.tplink.com/in/products/details/?categoryid=218&model=TL-MR3040#down
Sorry Rajan Ji I wrote only half... and thanks for the link... :-)
Worked with the old firmware....Only problem is router will not work if only 1x is available...
Are you sure the MTS modem is set to Hybrid mode and not to Broadband mode? Otherwise the modem would not work in 1x. Make sure to change the mode of the Modem by using on a PC and using the MTS connection software.
hi dude i can help in this thing pls try this i also use an mts data card i called tp link and they helped me here r some files u must upgrade the firmware which i will attach in this reply and some pdf file how to connect mts........https://drive.google.com/file/d/0B208ngaZpP4IMFJkVThGZnlSMlU/edit?usp=sharing
https://drive.google.com/file/d/0B208ngaZpP4INlN2YmVhb3hSMFU/edit?usp=sharing
https://drive.google.com/file/d/0B208ngaZpP4IbDYzQmMzeW5BNjQ/edit?usp=sharing
