Saurav
Sound Card Problem with Windows 8
I am using Intel DH67BL Motherboard with inbuilt sound card. I have also attached Creative sound Blaster Xtreme Sound Card.
My speakers are working very well in Windows 7 but on Windows 8 they give a humming sound in between. I have upgraded drivers.
Its happening both on Mother board outputs as well as sound card outputs. Pls guide.
Generally a humming sound from the speakers wont have much to do with software. You say that your speakers "are" working very well with Windows 7 but problem lies when you are operating on Windows 8. Did you upgrade from Win 7 to 8? This would indicate that you are no longer using Win 7, am I correct? Did you possibly place any kind of magnetic/electronic device close to your speakers? Could happen sometimes unknowingly. Or did you do the same with your PC? Maybe while connecting up an external drive etc? Electronic devices are known to interfere and produce the humming sound. Kindly check on all this since it is quite rare that software glitch can cause a speaker to hum.
Regards
Rahul
I am Using Windows 7 and Windows 8 on Dual Booting.
Edited by Saurav
It's electrical problem and hard to prove. May be you can change spike guard or plug socket... There is no sure shot solution for this..
Sent from my GT-N7100 using Tapatalk 2
