silent_god 121 Report post Posted May 3, 2013 @ ami1, Don't mind, but you can easily download any application apk from net. Just search "application + apk + download" & you will get the apk in one of the first 4 results. I have been doing it mostly in office, when don't want to use 1x/evdo on phone, whereas apk is required immediately, then I download it on computer & take it on phone & run. regards, 1 Share this post Link to post Share on other sites
kshah 452 Report post Posted May 3, 2013 @sadanand<br /><br />Nothing will work on nexus s 4g. Please don't waste time.<br /><br />I forgot the reason but it is related to codec. 1 Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted May 3, 2013 Thanks Kalpak ji... This method is working great... I am using the Maximum setting 15 in STDac in my RazrMAXX (GSM only) and 2 way calls are getting recorded without any issue... Share this post Link to post Share on other sites
ami1 237 Report post Posted May 3, 2013 @ ami1, Don't mind, but you can easily download any application apk from net. Just search "application + apk + download" & you will get the apk in one of the first 4 results. I have been doing it mostly in office, when don't want to use 1x/evdo on phone, whereas apk is required immediately, then I download it on computer & take it on phone & run. regards, Thanks for the tip. Got it from site called apkboys.com Just never struck me that there must be sites with direct download for all apks Share this post Link to post Share on other sites
ami1 237 Report post Posted May 7, 2013 (edited) CallRecorder working perfectly fine on Blackberry Z10 - using line recording and doing both ends fine, also automatically records all calls. All the other ones have some problem or the other. InCallRecorder says it can only record on speakerphone mode. Here's the BAR in case someone wants to install on BB Z10.polis.app.callrecorder_v1.0.24.0--WORKS.zip Edited May 7, 2013 by ami1 Share this post Link to post Share on other sites
drmadhu 87 Report post Posted September 8, 2013 STDac option is not shown on my alsamixer setting Sent from my XT907 using Tapatalk 2 My phone model is Motorola droid razr m xt907 Sent from my XT907 using Tapatalk 2 Share this post Link to post Share on other sites
