KanagaDeepan 1,084 Report post Posted September 23, 2012 (edited) Friends, here is a full fledged Dashboard for the ZTE modems from MTS (both ordinary MBlaze and MBlaze_Premium--FoldingType)... 1) Can send/Receive SMS 2) Make and Receive calls 3) Even has setting for 3Way con-call 4) Call and Data Log 5) Edit APN and DNS settings (like OG MTS dashboard) 6) Phonebook (both PC and RUIM) settings 7) Network mode selection (like OG MTS dashboard) 8) Activate / Deactivate services like call wait, call forward, etc 9) Set / change ringing tone for calls and SMS If you have already installed MTS dashboard, it may be removed before installing this dashboard... This may applicable to any other custom dashboard installed... Credit:- Thanks to Saket ji, who provided me the download link and all I am doing is just sharing it from my DropBox... All your wishes goes to Saket ji... P.S. :- I have thoroughly checked the features, especially I have checked voice calls of my Tata CDMA number TEN times before posting here... Download from HERE Edited September 24, 2012 by KanagaDeepan 15 Share this post Link to post Share on other sites
KAPILKDEV 68 Report post Posted September 24, 2012 Thank you very much Share this post Link to post Share on other sites
viper_in_blood 4 Report post Posted September 24, 2012 thanks a lot bro.. Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 24, 2012 Aalok bhai please advise should we change the dashboard given in your modem? KD ji many thanks. Sent from my Thunderbolt using Tapatalk 2 Share this post Link to post Share on other sites
aalok 442 Report post Posted September 24, 2012 +1 kanaga sir.. thanks a lot.. dipan bhai, will test it with the modem whether it works after unlocking or not (when embedded within modem), when i reach lucknow on wednusday as i am not having device right now with me.. though it will work when installed on PC with unlocked modems.. Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 24, 2012 OK ji let me know then will install! Share this post Link to post Share on other sites
mac_lion 13 Report post Posted September 24, 2012 thanks a lot ........ Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted September 24, 2012 I have tested myself with Unlocked MTS MBlaze PREMIUM (foldable one unlocked by myself) with TataCDMA RUIM... There is no way it can't work for aalok ji's case... Even if it didn't, you can just uninstall this dashboard and install the one that came with the modem... Share this post Link to post Share on other sites
admirer2000 100 Report post Posted September 24, 2012 (edited) ^ Not working with Mr. Aalok's - tried with Reliance CDMA Prepaid -------------------------------------------------------------------------------- "Start communication with the device" . . . with 20% it stops and then displays, "The device has no response. Please reinsert and try again." - OK (I have reinserted in different USB slots in my Laptop but result is the same) ------------------------------------------------------------------------------- (With China Net modem gets connected without any problem) Edited September 24, 2012 by admirer2000 Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 24, 2012 One question slightly off topic but with Aalok bhai's modems are you people able to use Chinanet 3g or only Chinanet 1x? I was only able to connect to Chinanet 1x using Reliance EVDO enabled RUIM. My question is if we are connecting Chinanet 1x are you still getting EVDO speeds? Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted September 24, 2012 ^ Not working with Mr. Aalok's - tried with Reliance CDMA Prepaid -------------------------------------------------------------------------------- "Start communication with the device" . . . with 20% it stops and then displays, "The device has no response. Please reinsert and try again." - OK (I have reinserted in different USB slots in my Laptop but result is the same) ------------------------------------------------------------------------------- (With China Net modem gets connected without any problem) This is common problem with ordinary MBLAZE modem. I experienced this when I used MTS service on MTS Modem ;p Just re insert in same port, it will start working.. even if it didn't work, just uninstall it and use old dashboard.. dashboard changing don't touch drivers.. so no need to worry.. One user confirmed that it's working with aalok ji modem by PM.. Sent from my iPhone like looking (for Sheeps) Galaxy Nexus using Tapatalk 2 Share this post Link to post Share on other sites
MVP 3 Report post Posted September 25, 2012 One question slightly off topic but with Aalok bhai's modems are you people able to use Chinanet 3g or only Chinanet 1x? I was only able to connect to Chinanet 1x using Reliance EVDO enabled RUIM. My question is if we are connecting Chinanet 1x are you still getting EVDO speeds? I have the same problem with bsnl (evdo activated) sim, can connect to 1x only. On ubuntu, I get 'No carrier detected'. Any solution to this? Share this post Link to post Share on other sites
drali 6 Report post Posted September 25, 2012 Only net is working, no sms and calls.Tested on my unlock AC2766 with tata & rel sim. Share this post Link to post Share on other sites
admirer2000 100 Report post Posted September 25, 2012 (edited) @digitalnirvana I am getting EVDO (China Net 3G) connected using Reliance CDMA Prepaid SIM. @kanagaDeepan Tried again & even removed the SIM and inserted again to try but it didn't get thru. Bad luck for me Sure, it will be very helpful if it works to send the allowed 200 SMS / day. Pls. try to get a solution. Thanks. Edited September 25, 2012 by admirer2000 Share this post Link to post Share on other sites
aalok 442 Report post Posted September 25, 2012 had asked my friend to check yesterday and got negative response... will be reaching lucknow tomorrow and will check again myself. maybe it'll work after some tweaks.. Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 25, 2012 One question slightly off topic but with Aalok bhai's modems are you people able to use Chinanet 3g or only Chinanet 1x? I was only able to connect to Chinanet 1x using Reliance EVDO enabled RUIM. My question is if we are connecting Chinanet 1x are you still getting EVDO speeds? I have the same problem with bsnl (evdo activated) sim, can connect to 1x only. On ubuntu, I get 'No carrier detected'. Any solution to this? Aalok bhai for your BSNL EVDO SIM is China net 3g working? Please excuse typos and brevity, sent while mobile. Share this post Link to post Share on other sites
aalok 442 Report post Posted September 25, 2012 dipan bhai, sometime it works, sometime doesn't. BSNL EVDO never worked at my residence but works good (though fluctuating since a month or so) at my office, which is just 700-800 mts. from my office.. Share this post Link to post Share on other sites
abhi5819 4 Report post Posted September 25, 2012 Only able to connect on 1x through Alokji's modem, tested with Reliance & BSNL RUIMs. While Micromax 300C works on both 1x and EVDO. Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 25, 2012 Is that with chinanet dashboard or this full dashboard? Share this post Link to post Share on other sites
abhi5819 4 Report post Posted September 25, 2012 Is that with chinanet dashboard or this full dashboard? This full dashboard doesn't work with Alokji's modem. Tried with MTS locked ZTE AC2746, everything worked except Voice Call. Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted September 26, 2012 May be MTS has disabled voice in MBlaze numbers... Share this post Link to post Share on other sites
srk006 21 Report post Posted September 26, 2012 @kanagadeepan Thanks a lot for sharing that software. I tried it on MTS MBlaze. it installed properly, but crashes if "Call Log is clicked" and voice call is not showing the dial pad, Share this post Link to post Share on other sites
aalok 442 Report post Posted October 3, 2012 one can check with the hardware manufacturer's website regarding voice/text compatability of the device.. triggered from tappa-talk 2... Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted October 3, 2012 @kanagadeepan Thanks a lot for sharing that software. I tried it on MTS MBlaze. it installed properly, but crashes if "Call Log is clicked" and voice call is not showing the dial pad, Your Modem is Unlocked or NOT??? Afaik MTS never allows voice/SMS (except bal checking) to their MBlaze data card numbers (even if its unlocked)... Please use it for any RUIMS on MTS unlocked modem... Share this post Link to post Share on other sites
Maulik.Parekh 34 Report post Posted April 10, 2013 (edited) With BSNL Dialer everything is working for me except SMS. When I click SMS it gives a blank screen but does not hang. Tried it on Win8 and Win7. I dont have china net dialer. Anyone has can you please share. Also please tell me how to enable SMS. Using R-CDMA on 2766. Edit: I also used visafone dialer from zte download page and with it SMS is working. http://www.ztemt.com/down.aspx?on=4&type=1&pg1=3 Edited April 10, 2013 by Maulik.Parekh Share this post Link to post Share on other sites
