Saiesh
How To Unlock MTS CDMA EC122 Data Card
I wanted help to unlock MTS EC122 Cdma modem so that i can use it with any CDMA service provider.
As MTS has no operation in Maharashtra and Goa since they did not bid for spectrum, this modem is lying with me unused, I see a Ruim Slot for this modem.
Hope u guys would be able to help me to unlock this modem.
Thanking you
Use DFS or CW, and try to get SPC [EFS method]
If you get SPC, it will be easy to using this one on reliance.
Also there are few posts on other forums to unlock and use it as RUIM,
But I havent tested it , so cannt say it will work or not.
thanks
I had followed some post in other forums, and tried to unlock using CDMA workshop but it was not possible.
Could u explain me what is DSF or CW and the detail procedure
sir
ec 122 is custom firmware software...
which will not only unlock with cdma workshop or efs dfs ....
sir
What does that mean
Firmware (software inside the modem) is specially made for MTS, and may not work for other operators.
you need to flash generic firmware of this model and do the unlocking process.
Get it unlocked by DC-Unlockr (a few minutes process) OR update the firmware using the link below. Will not require any other software or hidden process. Also attached in second link is the universal dashboard for all SIMs.
http://www.mediafire.com/?bdu1q55k89akvvl
http://www.mediafire.com/?ta6xcytthe7bih1
Sent from my N5100 Samsung Galaxy Note 8
  • Like 7
Download the firmware posted in the above comment. It will probably ask for a flash code for firmware upgrading. Use this tool to find the flash code. Once its done, your modem SPC will be reset to 000000. Now use CDMA WS or any other tools to change it to RUIM only. Done.
Edited
Removed wrong info...
Edited by KanagaDeepan
^ Sir, "RUIM, if available" works on those datacards which doesn't require firmware flashing, just to use default connection, based on "nv".
tapped from my phone..
How much did DCU charge to unlock E122 data card ?
For one modem, it is not worth buying full software.
Find some one locally who have DC-Unlocker, pay 100-200 to him and get it unlcoked.
even unlocking stores wont charge you more than 200.
I know place in mumbai they charge only 50rs for sim unlock for this kind of card or phones........
Hi All
I live in Mumbai and I have MTS ZTE AC 2787 data card. However, unable to use it since the MTS service has been discontinued in Mumbai. Please let me know how to unlock it to use it with other operator or the place in Mumbai where I can get it unlocked.
Thanks in advance for all the help you can provide.
Hi All
is it rev b modem?
Sent from my XT907 using Tapatalk
Thank you Pratul for replying.
I am not sure if its Rev b modem. Please tell me how to figure out if it's a rev b and what difference does it make ?
AFAIK this is not rev b and has 3.1 mbps speed (rev a). This has Qualcomm MDM 6085-1 cpu same as earlier ac2746 and ac2766. you can use the older trick to flash chinanet flash files but I'm not sure if this will work. The only problem is its spc is not 000000 as in the earlier mts modems where you could covert Non RUIM to RUIM and NV both.
You may brick the device in this process, better wait for a proper solution
unlocking not available for zte ac2787 as of now.
Thank you Pratul and aalok for replying. I have another MTS data card as well "AnyData ADU-555c" which I have tried to unlock with CDMA Workshop and I was able to unlock it. However, it does not have SIM card slot. If I can get the SIM card slot installed by any local vendor then is it possible to use it with other operators ? As i do not know much about flashing and updating firmware.
I will appreciate any help you can provide me regarding this data card.
I have used 555 which was mts had purchased it from ebay if I m not wrong.
they had created a sim slot on the divice
Sent from my GT-N7100
Yes Saiesh, actual modem comes with a space to install a SIM tray but no sim slot. May be the person who sold you this may have installed it before selling. I am not sure about this.
I will look forward to a resolution for this from all the experienced members on this forum. So i can make use of this modem to access the internet with other operators.
Thanks in advance for any help you can provide.
