huaweitrick
How To Avoid Prepaid Balance Going Negative When Using Data Plan in Tata Indicom CDMA
how to reduce going balance negative in tata indicom cdma
tata indicom cdma customer always balance goes negative while surfing internet due to their technical problem...
1) in tata indicom cdma there software would not able to find what the customer is using evdo serivce or 1 X internet
2) rember your auto renewal period ( means when u activated your internet)
3) all plans are autorenwal
4) 94 rs 4.5 gb plan also give u evdo speed while using username - MEID@omh.ttsl.in password - internet
5) suppose u have actived internet on 1 january rs 94 which validity is of 1 month.....VALIDITY end on 31 january ..meanwhile your mb finished........15 JANUARY
6) customer again active internet by sending DB95 TO 58265 ( 15 january) ,but plan u have activated on 1 january there software count your autorenewal period from 1 january not from 15 january.....
7) while on tata site your validity will shown from 15 january to 15 february..... customer think my plan will end on 15 feb...
but your autorenewal period 1 january after 30 days and on 1 february your plan will auto activate whether u have main account balance or not...
8) when u surf internet on 1 feb i m 100 % sure your balance goes negative......so check out your autorenewal period ..
second think when balance goes negative
1 ) u have some mb remaining in your account 400 to 500 mb ...
in tata remaining mb will update around 2 to 4 hours after using internet ..
2) so will going using your internet ...u thing your mb is remaining but after 4 or 5 hours when there system update it shows u have used internet without balance and they charge rs 10 per mb
3) so when in your account 400 to 500 mb remaining send msg UNSUB95 TO 58265 AND ACTIVATE OTHER PLAN ....
WHICH U WANT
4) REMAINING MB CHECK DP BAL T O12524
SO KEEP USING EVDO IN TATA @ RS 95 =4.5 GB ......BUT KEEP NOTICE YOUR AUTORENEWAL PERIOD .
  • Like 7
Good job Rahul.+1 for you..:rolleyes:
Sent from my XT901 using Tapatalk 2
Rs. 95 pack does not allow tethring on EVDO as per website. Only mobile browsing is allowed in EVDO.
download is also working with a 95 rs data plan in tata cdma.and it is like a mini 3G.me and Rahul(huwaitrick)also using it.and it is just awesome.
kindly check ur pm.
as per site 95 rs 4.5 gb plan is only for 1x...using evdo deducted money from main account ...but we use cdma unlocked modem for using in it .....and we get 350 plus downloading in idm,,,,,,,,,i will post a video soon... check it now
proof of evdo working in 95 = 4.5 gb and 48 =1.5 gb data....
http://www.youtube.com/watch?v=bMn47BPufmw&feature=youtu.be
Edited by huaweitrick
From my xp:
1. STV95 or others packs will give EVDO speed, provided you have EVDO enabled devices and a OMH RUIM of Tata Docomo CDMA/Tata Indicom
2. Don't try to activate this pack using your main account balance via Tata Docomo recharge portal. The amount will be deducted, but no data will be given. But complaining to CC will help you to get back the amount. So always recharge these packs from retailers or websites like paytm etc.
3. Post-bundled usage charge is high - check your data balance regularly. Send DP BAL to 12524 to get the remaining balance. The sms does not show the validity period, so try to note it down while recharging or keep the recharge successful message to check easily.
4. Suppose you have 5 MB data balance, and you connect to net to recharge another STV95. As soon as your recharge is done, your previous 5MB gets wasted and for the few KB your main account balance will be charged.
5. After taking all precautions there are chances you got negative balance. The IVVR does not tell you about negative balance. It says zero. But you can see your EVDO access is now blocked, only 1x. Call 198 to confirm how much you have in your negative balance. Recharge with Rs 150 to get full talktime.
  • Like 3
Nothing new here, have been using this for a long time ... , once you get into negative balance then the fun will begin and you will see how good their customer care is.
the validity can be checked on tata site by log in inti my account and register there.....
Best way it to use bandwidth meter on your PC and restrict it to your data limit.
Also keep your phone with sufficient balance , (top-up karana bhi jaruri hota hai)
Thats what we hate most. :giggle:
Thanks for pointing out. :pleasantry:
From 17th July, my tata sim is not latching to EVDO network. Its connecting to only CDMA network. I have positive main balance as well as data balance. It looks like they are blocking EVDO network for 95/- data plan users.
Free main to sirf advice milati hai...Baki sab ka paisa lagata hai :hypocrite:
English :- only advice is free of cost, everything else is paid !
sahi bat he hitesh bhai...abhi to advice bhi koi free me nai de raha...aap jese members is forum pe he wo bhot proud ki bat he
i was using this in maharastra and goa using unlocked dongle, if 1x is used the same was from data benefits but if i used evdo main balance was being deducted, this was may be a year back as of now i dont know the position would appreciate if any user throws light on the same
i dont why this os happens with you?i am using it right now on EVDO/HYBRID network my main balance never deducted yet.
Deduction of main balance depends on the username/password combination used.. ;)
tapped from my phone..
So what should be the user name and password. I will try once again by buying new sim as i dont have tata now
when showing cdma it means already in negative.. call customer care and ask fro balance.........
if not use proper setting given above....confirmed working 24 july 2012 6.38 pm
use above setting every thing will be fine
user name MEID@omh.ttsl.in password _ internet acess number #777
the mentioned combination works best for 2 or 3 Rs. 94/95 recharges and afterwards balance starts deducting from main (if available) or going negative..
This is my personal observation, and i may be wrong. Am no more a tata cdma user because bsnl evdo started working in my area with R-CDMA 94 pack (2 GB - 30 days) for backup.
plz note down everyone.....
if u r using meid setting then plz recHrge from main balance...........sending msg DB95 TO 58265
not from RETAILER OR PAYTM.....
IF U RECRAGE FOR RS 94 PLAN ACTIVATION MSG WILL COME BUT meid setting will not work balace will go negative
From when this change has happened????
After 4 sim balance goes negative I m able to find this.....@
sent by huaweitrick@gmail.com (samsung s3 )
I m using since past 1 year. Since ist I used zte 2746 unlocked cdma modem.....then huawei cdma modem now on s3 also........
