nitink
Mini MicroSD Card Reader for Android (solves the "No MicroSD Slot" issue)
to order : https://shopmeenova.appspot.com/st/order.html
about them : https://shopmeenova.appspot.com/st/p/m3r.html#devList
the project : http://www.kickstarter.com/projects/andyfei/mini-microsd-reader-for-android-smartphones-and-ta?ref=email
Due to hardware and software limitations of many Android devices -- especially older ones, this card reader is only compatible with the following tested and verified devices. It will ONLY work with devices listed here.
  • HTC One, HTC First, HTC One X+, Evo 4G LTE, DROID DNA.
  • Motorola Moto X, Droid Mini, Droid Ultra, Droid Maxx, RAZR M, RAZR HD, RAZR MAXX HD, Xyboard 8.2" Tablet.
  • Galaxy Nexus, Google Nexus 7 (2012 Original & 2013 New) & Nexus 10; requires third-party software or device being rooted.
  • Sony Xperia Z; Xiaomi 1S, 2, 2S, 2A, Xiaomi Box; Meizu MX, MX2; Huawei Ascend D2, Mate; Asus MeMO ME171.
Technical Specifications
  • Dimensions: 0.8"x0.9"x0.3" (21x23x8mm)
  • Outer dimensions when plugged-in: 0.8"x0.6"x0.3" (21x16x8mm)
  • Weight: 0.1oz (2.7g)
  • Interface: USB Micro-B, USB 2.0
  • SD card supported: MicroSDHC up to 32GB, MicroSDXC up to 64GB and higher.
  • Power consumption: 0.25w
  • PC compatibility: Windows XP/Vista/7/8, Mac OS X, Linux 2.6 and up; using USB-to-MicroUSB adapter (included).
  • Smartphone/Tablet requirement: Android 4.0 and up with power-enabled USB-OTG hardware capability and USB Mass Storage support in software.
Really small. Truly portable. Actually useful. Specially engineered for your Android smartphones & tablets.
Like an SD/MicroSD card reader that you often use on PC computers, except this one comes with a MicroUSB connector to plug into smartphones & tablets with MicroUSB port. Use it to play video/music on a MicroSD card. View photos/documents, copy and backup any and all of your files. Just like you are used to do on a PC.
Attach this coin-size card reader to your keyring and take it anywhere you go. Never run out of storage space again.
  • Like 3
LOL what a ugly device ...
you should post this in news snips..
it just like iball pen Drive, but little different
But still can't be used for Nexus 4 and may be upcoming Nexus Phone too...
its a boon for devices with no external sd card slot like the original HTC one , droid dna, moto x , few nexus devices. list of compatible devices is in post 1.
they started the project to get $5000 but ended with more than 70,000 US and it keeps rising every passing day.
we should give credit where its due.
its not that big
cb4d94db095d4bbce6675fcccb35b0eb_large.j
d31c4edded44725c2cf6f6489e6bf4ba_large.j
In which way its different than otg cable, microsd reader set?
In my old GNexus as well as nexus 7, root n stick mount app is needed, which is again needed here too. So what is the point here?
Sent from my Droid Razr MAXX HD using Tapatalk 4
no big deal, its just and OTG card reader
There are few traditional / older card readers which are not compatible when used on smart phone..
perhaps drivers issue.
These must be updated with the same.. :winko:
How you guys heard of MiMuCare? It's sorta like this one but it reads four different types of cards. M2, SD, MS,and MicroSD. And its the same price as MeeNova's. You guys should check it out.
