::Hitesh:: 1,763 Report post Posted August 31, 2013 This is not my method. This was done by Engine95 over at XDA. All props go to him.Be sure to follow this guide to the TEE.http://forum.xda-developers.com/showthread.php?t=2050582If you are on build zV9 you need to follow this guide instead.This is thanks to fiddy619!!http://forum.xda-developers.com/showthread.php?p=37447752Now you have to unlock your bootloader in order to remove bloat and install CWM or TWRP. You need to follow THIS guide. This guide will only install CWM. You will have to download TWRP and install through CWM in order to have that recovery instead. Props for this guide go to Team Codefire and Thecubed.http://forum.xda-developers.com/showthread.php?t=2002984 Enjoy !! 4 Share this post Link to post Share on other sites
ankurcshah 112 Report post Posted August 31, 2013 Highly recommended to use only TWRP with this phone guys. Sent from my LG-LS970 using Tapatalk 2 Share this post Link to post Share on other sites
Abhijeet Shukla 4 Report post Posted August 31, 2013 Will the evdo and other network settings change if the phone is unlocked? Share this post Link to post Share on other sites
joshm 818 Report post Posted August 31, 2013 Well would like to share a small bit from my side I have rooted my own and a couple of other LG Og what I feel is unlocking the bootloader of this phone sets in a bug in it more often than not. What happen is that the phone doesn't boot up properly and it keeps showing a black screen, you need to keep pressing the power button and volume down for like 2 or 3 times to get it to boot fully. Other than the issue of incomplete booting, i have never seem anu issue. Just my 2 cents, may it was just me and then phones that i rooted and unlocked. But whatever this is a fantastic phone, really awesome in every way be it screen, processing power, signal strength or evdo speed, everything is top class. Sent from my SCH-R950 using Tapatalk 2 1 Share this post Link to post Share on other sites
snorlax 319 Report post Posted August 31, 2013 Even I have done it with three optimus g but never faced the problem Josh. Did u unlock Bl by freegee? And also did u unlock sbl before booting? Share this post Link to post Share on other sites
joshm 818 Report post Posted August 31, 2013 On 8/31/2013 at 2:31 PM, ankitdaluka said: Even I have done it with three optimus g but never faced the problem Josh. Did u unlock Bl by freegee? And also did u unlock sbl before booting? That's a standard thing ankit, freegee is the best and you have to backup the efs no matter what Sent from my SCH-R950 using Tapatalk 2 Share this post Link to post Share on other sites
snorlax 319 Report post Posted August 31, 2013 I said Coz I faced issue in reboot when I had Bl unlocked but did not unlock my sbl. Even autoprime always suggests to unlock sbl if only unlocking the Bl gives boot issues Share this post Link to post Share on other sites
ankurcshah 112 Report post Posted August 31, 2013 I never faced any issues whatsoever! I used freegee as well and was all good! Best freaking phone! Share this post Link to post Share on other sites
mpva 9 Report post Posted September 7, 2013 Hi everyone I am having difficulty in using Evdo with this phone. Evdo is activated but I am on 1x only. Is it a radio issue? I am on ZVB. Any help will be greatly appreciated. Share this post Link to post Share on other sites
Maulik.Parekh 34 Report post Posted September 23, 2013 Hi Guys .. I have just got the phone is on ZVB .. is it safe to upgrade it on ZVC ? about 93 MB of update .. Share this post Link to post Share on other sites
Maulik.Parekh 34 Report post Posted September 29, 2013 After some guts yesterday I backed up efs partition and upgraded ota to zvc .. to my wonder data was working .. .. hence i confirm that for me data was working on ota update to zvc. Share this post Link to post Share on other sites
