KanishkGandharv
Sprint LG Optimus G EVDO Solution
Getting the PPP username and pass to stick seems dificult with this model to some users, the parameters gets reverted to stock on every reboot it seems. Use the attached file and write it via either CDMA Workshop->Memory->NV Items->Write or use the free NV reader/writer program from here. After writing the file, re-write your own parameters with program and check after reboot.
Download the file from here.
  • Like 8
The custom roms, I have tried couple of them( CM 10.2 and Carbon) but data don't work on either of them.
Worked like a charm!!!!! Thanks a ton!!!! :signthankspin:
Data works with 4.2.2 AOSP Roms
Dear Gurus,
Still on Stock .. I will enjoy it for some more days though ( got LGOG 2days back) ...
I am getting an update notification from ZVB to ZVC ... Is it safe to update to ZVC ... any observations like losing data etc .. based on yr response I will decide to upgrade or not ..
Hi guys,
I am using LS970 on stock, for which I got OTA update for ZVC(currently I am on ZVB)
Is anybody using it on stock ZVC update with data ?
I want to confirm it before updating .. I can not afford to not have data ..
Thanks ...
Guys , can anyone tell me whether data works with 4.3 or 4.4 custom roms for this phone. ?
Yes, it works. You may need to copy apn configuration file from stock rom to custom rom.
Sent from my LG-LS980 using Tapatalk
