keval32
Tutorial: Get Data Working For Samsung Axiom SCH-R830 US Cellular On Jellybean
good work buddy... just out of curiosity.... anyone else tried on reliance / tata ?
the modem file you gave says invalid md5 check... any other link please....
CONFIRMED... 100% working with reliance OMH.. ! :signthankspin::thumbup::clap1:
Thank you man! Glad my post helped you! Thank you so much! :)
i followed the same procedure by to you, but nothing working. showing message that insert sim card to access network services , even though sim is inserted and calls & SMS are working properly on reliance OMH.
experts please help me to reolve this isssue. thanks in advance
Do not try from the drop down notification menu.
Once try going into setting and then mobile network and switch on data from there.
That should help I believe.
Thanks for your reply, i tried the going into setting and then mobile network and switch on data from there. it is showing mobile data is on , I have activated EVDO on my OMH sim, it is working in my stellar.
I have opened the browser , no data . Please help
Here is one uploaded by fellow Rimweb member : http://www.mediafire.com/?i8ae6c15mg2g5cs
Password for this is : kanishk@9093
Please update the original post with this information so that everyone should download the correct file.
not working on tata cdma omh based sim card
and also on reliance cdma omh card
tried all the above procedure perfectly
pls post any other options..
buddy it works 100% even i had problems initially... all i did was restored its NVDATA using adb and then tried and it worked... you know how to use adb? if not i can help (dont do aything if you dont know what are you doing... it may brick your device)
is this ..
same as samsung s3 r530 us cellular nvrestore command
will try and tell u it worked.
thnks for reply
is this ..
thnks for reply
Yes this is the same command... sure buddy... all the best... :thumbup::Boy Thumbs Up::thumb:
is this ..
thnks for reply
not working tried with "adb reboot nvrestore"
still same
can u show me the detailed process
After entering NV command via adb your phone should boot upto Samsung logo but no further if it goes beyond and settles the OS that means it requires few more tries. adb reboot nvrestore can also be given while on MD4, MB1, LH2 and LG1. Safest downgrade is LG1 because hidden menu works on it. After OS boots completely, dial *#22745927 and enable hidden menu, back, dial ##3282#, edit, ->others->HDR/1X selection, select none other than LTE+EVDO+CDMA, back in others click Korea mode and select India mode. Reboot. After data starts, root it so OTAs will be blocked for installation. Rest do not give a silent update to 4.3 MK2 firmware OTA or data will stop immediately and Knox security will prevent downgrade to lower builds. One can remove knox and downgrade again to any firmware levels but that method is still not well established.
Sent from Sprint L720
samsung axiom r830
data works on 4.1.2 jelly bean--baseband-R830VXMB2
with adb coomand 'adb reboot nvrestore'
but loose data connectivity after restarted
when data was connected it was showing-on mobile network type 1xRTT:6
but after restarting
it looses data connection and shows on mobile network type EvDo-rev.A:8
EXPERTS PLS HELP;..
samsung axiom r830
EXPERTS PLS HELP;..
Just flash as per my method, you won't get data stopped after restart.
Not working on TATA OMH sim i follow your process
