basheerbr
HTC One Soft Bricked - Please Help!
Wipe delvik cache , cache, internal storage, data all and reboot without updat rom . My Sprint HTC one stuck in quitly brilliant screen , do relock and runn ruu , shows error 120 main battery low, my battery is 100%, please help
try to wipe battery stats
or flash ruu from fastboot
Flash ruu from fastboot shows 120 error , how to wipe battery status?
Adb push Rom , but it can't see on recovery
Bootloader unlocked, flashed recovery .
If relocking boot loader flashing recovery and custom rom doesn't work take it to a local mechanic take the battery out and charge the battery directly then flash ruu.
Heard about otg cable, that solve my problem?
Connect otg cable go into twrp recovery
Mount USB otg and flash rom from your pen drive. Or try connecting your phone to your pc and do adb side load the rom.
Unlock bootloader install CWM Recovery & select install zip from sd card than install from sideload connect cable to pc type in adb "adb sideload path of your rom"
you will need a custom rom to do this
sideload will transfer the file from pc to device without the need of OTG cable & flash it
Hope this helps
Thanks Hitesh, kanishgandharv,nikmea1cellsolution, , solved the issue, Windows 7 shows error 120 main battery low, I try on Windows 8 solved HTC one soft brick. Sprint RUU run through fastboot usb successfully with bootloader relock.
Solved , thanks, everybody flash ruu through fastboot usb on Windows 7 failed error 120 main battery low, done through windows 8 after relock bootloader successful
superb thread and super helpful and extra nice ppl!
thats why i love rimweb!
cheers!
hello everyone... i recently bought a sprint htc one from USA through my sister who lives there...
I was trying to unlock the phone by flashing an RUU and running sim unlock app... but while flashing an RUU i got an error and it stopped in the middle...
Now basically its rom-less it gets struck in htc quietly brilliant screen.. i cant access internal storage to flash stock rom..but i can access bootloader..
My phone details
Bootloader unlocked
S-OFF
hboot version 1.55
TWRP rcovery installed
please help me out....
Get rom zip from XDA
Boot to twrp recovery
Wipe all
Then mount USB storage
Copy rom zip to phone.
Then from install option install rom zip
Sent by Moto G on Reliance CDMA
That might not work since thr is no usb mount option i guess.
Alternatively, since you have twrp installed, you can try the following method;
Make sure device is showing up in adb
-- adb.exe devices
Push the favorite rom to phone
--adb.exe push C:\blabla\blabla_rom.zip /sdcard/
Once the adb prompt shows success, head to twrp and install zip.
-- adb.exe devices
i am trying it form 2 days... adb dosent detect the phone... i also cant sideload the rom... i guess i will have to try using the usb otg cable...
Wipe all
i will try this procedure tomorrow... but are u sure it will not do any further damage to the phone???
thanks in advance.. :smartass:
This will work only you have twrp working , also in twrp there is option to mount internal / external storage as USB .
i tried that procedure...
twrp is working... but when i go to mount option.. it says usb-otg (0 MB)... i cant select it... it also dosent get loaded...
please help me out bro...
thanks in advance
my bootloader reads
***TAMPERED***
***UNLOCKED***
M7_WLS PVT SHIP S-OFF RH
CID-SPECS_001
HBOOT-1.44.0000
RADIO-1.00.20.1108
OpenDSP-v32.120.274.0909
eMMC-boot
You are trying to mount external USB drive.
Mount internal or external memory .
Also if u have otg cable then you can use pen drive and flash rom from USB pen drive.
how to mount internal or external memory???
in TWRP i can see files like /data /cache etc. but i cant see my backup and other roms...
i tried otg cable but when i plug it into the phone it dosent detect it...
First relock bootloader, to enter command fastboot oem lock through ADB , then run stock RUU , solve Ur problem.
i have s off i dont think i need to relock bootloader... but miraculously in my friend's pc its showing up in fastboot
C:\Users\Praveen-SK\Desktop\HTC One\adt-bundle-windows-x86_64-20140321\sdk\platf
orm-tools>adb devices
List of devices attached
orm-tools>fastboot devices
FA344S900731 fastboot
orm-tools>fastboot getvar all
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.44.0000
(bootloader) version-baseband: 1.00.20.1108
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 3.05.651.6
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) serialno: FA344S900731
(bootloader) imei: 9***********10
(bootloader) meid: 9*********11
(bootloader) product: m7_wls
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0720000
(bootloader) cidnum: SPCS_001
(bootloader) battery-status: good
(bootloader) battery-voltage: 4045mV
(bootloader) partition-layout: Generic
(bootloader) security: off
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
getvar:all FAILED (status read failed (Too many links))
finished. total time: 0.063s
now what should i do??? please help
thanks in advance
just run RUU from the pc on which you can fastboot
@Praveen,
You need to relock bootloader to run RUU.
you can unlock again after ruu is done.
but hitesh bhai, no need to relock as its s-off
