silent_god 121 Report post Posted December 2, 2013 Dear Friends, Issue is - Some stupid applications, getting downloaded without my permission & shows some Chinese title in notification bar. Since, last few days, this issue, is troubling me on my Epic Touch 4g (ET4G). I can't ascertain the reason for this & have tried multiple checks but no results. Attached is screen shot for one such app, which permanently remains in 'ready to install" position in notification bar. Could any one point me to solution for this ? I have GB 2.3.6 EL29, device is rooted. Any way to find out ? https://drive.google.com/file/d/0B2GAO5pOPfbTbTdRdllwTWZYZFFOUFk4NVVKdzZQSnRSWGZj/edit?usp=sharing https://drive.google.com/file/d/0B2GAO5pOPfbTNjJqWFc5QnZPVlFIQ1NnZ0hsb2sydG1STGJj/edit?usp=sharing Thanks in advance. MODS, I have searched forum for such issue, but without proper tag work, I am unable to find any specific post, hence started a new post. If you can find relevant post, kindly merge this in order to cleanup. Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted December 2, 2013 First, change your google account password. Then scan your laptop/computer for appcaster. It may be called Mobile App Sync in control panel. Uninstall it. It may have access to your google account & found out to be the culprit for such unwanted app installation in many cases. Also search for any such other crappy Sync apps having access to your google account which you might have installed on laptop/pc/phone. You can also try an app called Addons Detector which helps in finding spammy apps >> https://play.google.com/store/apps/details?id=com.denper.addonsdetector&hl=en It also helps in detecting apps with push notifications so you may zero out on the culprit app. 1 Share this post Link to post Share on other sites
silent_god 121 Report post Posted December 2, 2013 ^^^ Thanks for quick response. Tried "Addons Detector", but it's complicated & couldn't figure it out about the solution. Check on computer is not yet done. Will be done tonight. Thanks. Share this post Link to post Share on other sites
