dr.faramroze 703 Report post Posted December 20, 2013 Verizon has launched a ditto copy of Samsung Galaxy Stellar named Samsung Legend model no. i200.PP. This phone is marketed for their so called prepaid service. US sellers are getting confused or deliberately shipping i200.PP in place of the original Samsung Stellar i200 as the handsets are identical. This handset does not have a SIM card slot and the other distinct difference is in the MEID series. This phone has a series starting from A000XXXXXXXXX. Phone ships via 4.1.2 so hidden menu and other fixes and tweaks stop here. To map the diag port, download the attached utility. Use your favorite CDMA tool and a Samsung i605 password and the SPC will be displayed. Note that the SPC of this phone is not 000000 though its Verizon. All data parameters have been successful in programming this handset on our network. PhoneUtilss.apk 13 Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted December 24, 2013 thanks for the info, Actually I was thinking of getting this phone and putting stellar ODin on it, for using it on Rcdma sim . you saved my efforts !! Share this post Link to post Share on other sites
Genius 817 Report post Posted December 24, 2013 (edited) Good one doc mods please merge this with already running thread for diag mode http://www.rimweb.in/forums/topic/34656-diag-modedrivers-for-mobiles/ Edited December 24, 2013 by Genius Share this post Link to post Share on other sites
KanishkGandharv 46 Report post Posted January 15, 2014 An easy way to enable diag is to use ##DMMODE#. Also i should suggest members not to Odin the i200 files on i200PP, the bootchain might be differ on both models and your phone might get bricked. 1 Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted January 16, 2014 On 1/15/2014 at 5:25 PM, KanishkGandharv said: An easy way to enable diag is to use ##DMMODE#. Also i should suggest members not to Odin the i200 files on i200PP, the bootchain might be differ on both models and your phone might get bricked. It dose get bricked! But in NV mode everything works perfectly! tapatalking.... 1 Share this post Link to post Share on other sites
astrokidvaibhav 37 Report post Posted January 31, 2014 I ordered stellar phone and was shipped legend instead.. Thank you for this thread.. Clears many of the doubts I had.. 1 Share this post Link to post Share on other sites
snorlax 319 Report post Posted February 9, 2014 Please be warned that performing a factory reset on Samsung Legend WILL result in your MIN getting deleted from the handset in addition to loss of NV items. Resultantly, after reset, neither will you be able to make/receive calls/sms nether will data work. So, before doing a factory reset, make sure you have your NAM saved and have your SPC and NV Dump at hand for reflashing. I learnt it the hard way recently so thought to share. 2 Share this post Link to post Share on other sites
shreesh 406 Report post Posted February 9, 2014 Not only for this phone but for all of the phones, buyer should note down their MIN no.to avoid hustle and bustle in future. Sent from my VS950 4G using Tapatalk 2 Share this post Link to post Share on other sites
ni0987 179 Report post Posted February 9, 2014 ^^^ Thanks for this life saving info.. Share this post Link to post Share on other sites
::: VA ::: 531 Report post Posted April 10, 2014 okay i put this app but still stuck on what to do. how to get the phone in diag mode. plus the phone doesnt show any usb options when connected to pc. no mtp or mass storage. how exactly do i determine the spc? please guide me. Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted April 10, 2014 ^^^ Use attached APK to open Quallcom USB settings or use SAMIOTA app by HP to get diag mode on. Share this post Link to post Share on other sites
astrokidvaibhav 37 Report post Posted April 10, 2014 Check device manager to see whether it shows what port the phone is connected on.. Use that app to switch from MTP+ADB to DM+MODEM+ADB.. I have changed spc of your phone to 000000 earlier so it is the same now and finding that is not a problem.. Share this post Link to post Share on other sites
::: VA ::: 531 Report post Posted April 10, 2014 Finally I could get this phone to talk last night. But it was already in DM modem adb mode. I can't change it to mtp. So diag mode is sorted but can't seem to get it in mtp mode now. sent from my Moto G - Reliance Share this post Link to post Share on other sites
astrokidvaibhav 37 Report post Posted April 11, 2014 Open App --> Open Diag Menu --> Select PDA --> Tap on Qualcomm USB Setting --> Select required option Hope that helps.. Share this post Link to post Share on other sites
