maniac8828 24 Report post Posted December 24, 2013 Posting method to get SPC, MSL and update prl on LG G2. Used it with Spring G2 and confirmed working. Original method here and all credit goes to the owner but just thought I would share here - http://forum.xda-developers.com/showthread.php?t=2521276 1. Make sure USB debugging is enabled.2.Run SPC Toolbox3.Click Scan ports4.Select correct port5.Click 'Connect'6.Select Method7.Read SPC8.Read Device I was able to get my Sprint G2 programmed for Reliance using this method. This tool does not require any rooting 1 Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted December 24, 2013 How to update NV. Without it im sure EVDO is not possible. Share this post Link to post Share on other sites
phonegeek 588 Report post Posted December 25, 2013 (edited) Easiest method to get SPC: Dial ##443336772# and your SPC/MSL will be displayed on the screen! Probably this will work for other LG phones also. Edited December 25, 2013 by phonegeek 2 Share this post Link to post Share on other sites
maniac8828 24 Report post Posted December 25, 2013 I think we can use LGFlashTool to write NV file in Download mode and it should work. Share this post Link to post Share on other sites
KanishkGandharv 46 Report post Posted December 26, 2013 I probably dont think that works, i tried that thing with the Optimus G. However you can try the posted NV Item file to check the EVDO. Share this post Link to post Share on other sites
phonegeek 588 Report post Posted December 26, 2013 (edited) Is it possible to enable evdo by changing the data value to undetermined in hidden menu settings? Code is 5689#*980# Edited December 26, 2013 by phonegeek Share this post Link to post Share on other sites
KanishkGandharv 46 Report post Posted December 26, 2013 The NV File posted does the same as the code. And the code probably works fine too Share this post Link to post Share on other sites
phonegeek 588 Report post Posted December 26, 2013 So were you able to get evdo working? Share this post Link to post Share on other sites
nishsuxx 193 Report post Posted December 26, 2013 NV flash for sticking EVDO settings is old school (no offence) Just change it using code and peace life... @Saurabh ... kindly add the code in this Thread Also .. has someone faced issue with LG handsets ... when MDN is transferred to the LG handset the response of "ODR RSN" to 53737 says that the phone has not been OTAFED. Though Text / Call and 1x work even in this state but makes evdo activation pain in donkey. This has happened with me on 3 LG handsets ... Any solution ? Share this post Link to post Share on other sites
KanishkGandharv 46 Report post Posted December 26, 2013 Yes it is oldschool, unless you the know proper dialer code and unless the Provisioning file is there in the system. I have shuffled through alot of LG phones on which these codes doesnt work but writing the file does. Its just basically the same stuff, and you might want to cross check before buying LG phones that they are indeed working on EVDO. There are many phones now on which even if the EVDO settings gets sticked, EVDO will not work. Share this post Link to post Share on other sites
phonegeek 588 Report post Posted December 26, 2013 So g2 falls in which category of handset? Share this post Link to post Share on other sites
KanishkGandharv 46 Report post Posted December 26, 2013 I guess it should fall under easily flashable category. The code does works on this phone but i cannot confirm whether it helps or not since i do not have the phone. Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted December 26, 2013 Working Share this post Link to post Share on other sites
phonegeek 588 Report post Posted December 26, 2013 (edited) Vinodji, earlier you mentioned that it may not be possible, any specific reason for the same? Thanks kanishk. Edited December 26, 2013 by phonegeek Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted December 26, 2013 I knew it works for sure. But was not sure how to make it work. Do not have phone in hand. Getting it maybe this weekend or early next week. Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted January 4, 2014 Yes it is oldschool, unless you the know proper dialer code and unless the Provisioning file is there in the system. I have shuffled through alot of LG phones on which these codes doesnt work but writing the file does. Its just basically the same stuff, and you might want to cross check before buying LG phones that they are indeed working on EVDO There are many phones now on which even if the EVDO settings gets sticked, EVDO will not work. Been trying hard to fill PAP settings through DFS and for some reason it's not sticking. Can you help ? Sent from my LG-LS980 using Tapatalk Share this post Link to post Share on other sites
phonegeek 588 Report post Posted January 4, 2014 Have you changed the carrier to undetermined? I have configured one G2 last weekend only. Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted January 4, 2014 Have you changed the carrier to undetermined? I have configured one G2 last weekend only. Yeah bro, and set the 39939 to all 00. The PAP is not sticking. Can you help? Sent from my LG-LS980 using Tapatalk Share this post Link to post Share on other sites
phonegeek 588 Report post Posted January 4, 2014 Check PM Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted January 4, 2014 I have configured one G2 last weekend only. Check PM If one PM's the solution to other member privately, what's the need for posting here saying PM'ed / Check PM! Any solution should be posted here in the topic so other members can also benefit. Unfortunately since some members have become handset sellers (& interested only in that activity), more such posts are noticed. Sharing of knowledge has stopped. PS: This is a general observation, not directed at anyone in particular. 4 Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted January 4, 2014 Rajan Bhai. Will post about it once everything starts to work. Step by step bro. Sent from my LG-LS980 using Tapatalk 1 Share this post Link to post Share on other sites
phonegeek 588 Report post Posted January 4, 2014 Rajan Ji, I have PMed him my email ID so that I can tell him step by step process and also in case required, do it via team viewer. Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted January 4, 2014 no luck "Unable to establish a wireless data connection" anybody has any idea why im getting this error message on my LG G2 ? Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted January 4, 2014 ^^^ Have u tried making it RUIM Only mode from DFS and using a SIM, One of member confirmed same last night, he is using TATA on sprint LG G2 with sim , with data that too without GSM unlock. Share this post Link to post Share on other sites
Vinod Nayak 443 Report post Posted January 4, 2014 That works but i want it work with nv. Want to know why im getting the "unable to establish a wireless data connection" any help would be highly appreciated Sent from my LG-LS980 using Tapatalk Thats a sprint activated phone. Mine is not. Not sure if it will work. Sent from my LG-LS980 using Tapatalk Share this post Link to post Share on other sites
