pbananth
Please suggest Highend CDMA+GSM dual standby
hello gurus,
kindly recommend a high end android smart phone..
1. dual standby cdma+gsm
2. 3g (cdma and gsm)
and also whether available with our members..
thanks..
HTC desire 600c. Comes around 28k
Edited by maniac8828
HTC One dual sim.
Appx 42K price.
Only catch is that Slot-1 supports HSPA as well as EVDO Rev B.
But Slot-2 supports only EDGE.
@maniac8828:
Searching for HTC Desire 800 only returned Lumia 800 and no Desire 800 :unexp:
HTC One dual sim.
Appx 42K price.
@maniac8828:
Sorry bro, search for HTC Desire 600c. Wrote from my phone so messed up :P
HTC Desire 700
Now whether to call it high end will depend on individual perception & needs but it's a less costly alternative to HTC One Dual SIM for a 5" CDMA+GSM phone with many software/hardware elements from HTC One like blinkfeed, Sense interface, HTC Boomsound Dual Front Speakers, HTC Imagechip BSI Camera incorporated.
  • Like 3
^^^ Looks like HTC for some reason applied its same principle of HTC One Dual Sim in HTC Desire 700, that is 3G works in only SIM Slot:1, so it may not fit the OP needs. So, request OP to note this before jumping on this. But I guess, it is very difficult to get a high end phones with dual sim(that too CDMA & GSM) & 3g on both sims. So, your best bet is to sacrifice data network on one of the network(either in GSM or CDMA) and use Desire 700 or HTC One dual(which is way high budget).
thanks..
so HTC desire 700 will fit the requirement.. Yes?
i am using s2 epic touch purchased from Parin..
i can able to change the number to Reliance Sim and use?
kindly clarify ..
again thanks..for all...the gurus..
Yes you can use Desire 700, but pls note that(as I've already mentioned in my previous post) only in one sim slot(slot: 1) 3G(EVDO or GSM 3g) will work the second sim is only 2G capable according to the official specifications on HTC website that Rajan ji provided link for. HTC One Dual also has same setup, if your budget permits then go for HTC One Dual(which may costs around 40-42k) or HTC Desire 700
HTC dual SIM phones are no exception. So far no manufacturers have come up with models that provide evdo/umts/hsda on both slots. In fact you can't turn on data on both Sims at same time either. So it makes sense to save cost on radios.
thanks..
so i will wait..or i am going to shift to Airtel GSM..
Could any one tell what version of android is on HTC DESIRE 700
