HarshaRim
Motorola X Verizon Wireless - GSM Not Working
Hi
Everyone jst today itself got My Customized Moto x this one is Verizon wireless im inserted idea gsm sim when im insereted i got idea signal but not able to call or msg anyone later than changed frequeiences still no luck after that reflashed still same issue network being registered to idea but instantly idea and immediately showing emergency only or the selected network not available when i change to global mode there is full signal with No Service text i can use Cdma with data..but i cant use gsm can anyone tell me whats going on? please help me
Moto X Customized from Verizon & AT&T
U cannot Unlock
Only Stock Black & White are Unlocked
So I I can't use em' right ? No way to unlock if yes I'm f**kd seriously
post-65651-0-13333100-1390222942_thumb.p
Am I wasted my money? Should I sell it ?
post-65651-0-27759800-1390222998_thumb.p
post-65651-0-42202500-1390223015_thumb.p
No 1 will buy locked version.
Sent from my VS950 4G using Tapatalk 2
@HarshaRim, you said you can use CDMA, so it's not completely waste of money, you can use it on any CDMA network.
Guys my frnd also had customized Moto x and I have droid ultra we are using gsm on both phones not Able to only on my phone any suggestions guys
GUYS WATCH THIS VIDEO PLEASE
I have bought a new Moto x Verizon with omh and gsm support.
It's showing KitKat update moment I connect Wi-Fi.
Is it safe to install it? Without losing unlocked mode.
I was confirmed by gurus that it's safe to update to KitKat and I did successfully. :D:):P
After update is it working on OMH & GSM for call, text & data
Have you retained root?
Is it 4.4 KitKat?
If so, then next KK update 4.4.2 is coming in a matter of days, afaik... If you want to retain root access, wait before taking 4.4.2 update and have a close look at xda. Root for 4.4.2 will be eventually be available, but its NOT at all going to be a simple task, let alone one click, afaik.
Afaik, root for Droid phones running KitKat 4.4 are NOT released to public, because Moto may patch the vulnerability in next 4.4.2 update. So, once 4.4.2 was rolled out to all Droid (MAXX, Mini and Ultra) phones, we may see root procedure (not going to be a one-click or simpler task again).
But root for X is a different story. Root for 4.2.2 is available for X and Droid models. And for X already running 4.4 can be downgraded to 4.2.2 and get root and update to 4.4 + root retained. But in case of Droid models which got 4.4 after X, this flaw is corrected and downgrade of firmware is stopped by doing a signature check, before flashing via stock recovery.
I can see a mild light coming from other end of tunnel. If my MAXX got root, then it will be the best mobile at that moment (for me atleast).
I don't require root in Moto x as its for my dad. Yes it has retained everything on omh but gsm not tested.
Tested again I was on Wi-Fi.
No data on omh, only call and sms.
It's on 4.4 right now.
Edited by ::: VA :::
Does gsm and cdma work on xt1060 with data on both..thanks
Sent from my SCH-I605 using Tapatalk 2
still stuck on moto x verizon for data with reliance cdma omh.
sms and calls work. but no data which is sorely missing.
Update: after putting a new omh SIM in Android 4.4.2 Moto x Verizon evdo data works perfectly smooth
I am planning to use Droid Maxx for CDMA (for my dad). What was the difference between the old and the new SIM for data to work?
Just confirm that is your SIM OMH one or not. If it is a OMH one then no problem with EVDO else 1X :-(
Triggered from SCH-r530u using Tapatalk Pro
@ VA/Parin/anybody else:
Can you please confirm whether Wifi tethering works with CDMA?
Need little tweaks and it works !
Sent by Moto G on Reliance CDMA
pl explain how to get WiFi tether on Verizon moto x, as can't root non-de on kitkat
