pbananth
Suggest a GSM Handset
gurus..
recommend a GSM phone..
1.with Wifi hotspot..
2.HSPA+
3.battery life..
4.preferable android..smart
5. upto 15000/=
thanks..
Wait still 5 Feb moto g launching in india
Sent from my XT907
is there phone less than 10000/=
with the above specification/
thanks..
Ha ha ha ...
Tumko Gabbar chahiye .... woh bhi zinda!!
thanks..
Obviously you can't get a phone equivalent to Samsung Note 2 below Rs 10,000.
If it's large size battery you are after, try Micromax Canvas Juice A77 which has 3000 mAh battery & should cost below Rs 10,000.
Canvas Juice A77 Specs
There was a good deal going on the LG Optimus G 970 on ebay , have you checked that out ? (its a nexus 4 sister phone)
canvas juice is a very good mobile as suggested by RM ji.
and if you want even more powerful battery and brand value then go for lenovo p780 but cost is approx 15k.
Thanks for all suggestions.
This is secondary phone specifically used to access net for ipad..
That's why searching for a low price.. But 3g essential and wifi hotspot..
Thanks again..
I am looking for Blackberry 9220. Cheapest I found was on flipkart for 8600, Any better deals please..!!
