::Hitesh::
Tutorial - Flashing Stock Firmware on Moto G
Noob question, but Can we flash firmware using RSdlite ?
No, current version on RSDlite dose not support Moto G
Ok another noob Q - which one do I download for Reliance CDMA ?
Android 4.4.2 KOT49H.M004 - I hope i am correct on this
There is no reliance specific rom of zip
U need to use original carrier file.
If u have boost use boost file.
If Verizon use Verizon.
Just save your min before doing this !
tapatalking.....
can some 1 help me with this tool kit??
You have adb issue, either drivers are not installed or adb connection is not authorized in phone.
tapatalking.....
stuck with this tool kit.
4.4 not updated and now 4.3 not booting.
something is wrong with this tool kit or maybe i have done some thing wrong so be careful while using this kit.
I will help u on Sunday
tapatalking.....
great thanks for reply. :hi2:
please whatsapp me the time also i will be ready.
Edited by cooladitya007
need help guys.
i was trying to Flash Stock Firmware on Moto G with Moto G boost 4.4.2 kitkat restore tool kit
https://docs.google....export=download
but failed now mobile is not booting properly, when i turn it on it stuck at M logo screen and restart again and again.
your help and support highly appreciated.
thanks
Contact hitesh Bhai, he is the Moto g expert:)
check PM
finally get help and support from hitesh
thanks a lot.
Thanks Hitesh for the tool kit. Its working great! :)
If I flash Boost image, will I continue to receive Reliance EVDO/CDMA signals and Data? Do I need to punch in APN for Reliance upon completion of flashing?
If u flash boost image u won't get signals .
Prl and data settings need to be redone
Sent from my Moto G using Tapatalk 2
Dear Hitesh Bhai ,
Thanks for such nice blogs on CDMA knowledge base especially Reliance & Moto G.
I have Moto G Boost flashed for Reliance CDMA during 03.2014.
It has updated to 4.4.2 recently and in a market , I paid a good amount to reprogram it for
Reliance CDMA. I am getting calls but not able to do most of outgoing calls as calls drops
before connecting. Some numbers are connecting not others.
I want to flash 4.3 stock ROM in this moto G phone as same was working well since 6 months.
I have prl file , MIN & can use CDMAtools.
I am downloading http://sbfdownload.droid-developers.org/download/falcon/falcon_boost_user_4.3_14.10.0Q3.X-84-9_11_release-keys-cid9.xml.zip
for further flash it to moto G as per procedure laid in post.
After flashing 4.3 , I will upload prl file , Enter MIN..
Can I download data dump file /settings for 3G/EVDO from existing phone before starting for downgrading it to 4.3 by CDMA tools?
So that I can re-up these data dump/network settings back to downgraded ROM.
It would be kind to tell some steps to do so i.e.
1. FLASH DOWNGRADED ROM.
2. Program it for Reliance CDMA (If we know MIN/prl already)
3. Should we need to contact Reliance Call Center after such flash of ROM?
etc.
Please help Hitesh Bhai .....
Regards
all moto G stock rom works perfectly, must be some settings in assisted dialing or saved number format .
if you have your min, you can load any rom available for moto g and after putting correct PRL your calls and sms should work without any issue.
but for data you need a data dump or HDR password. without that you cannot get evdo. 1x is possible without dump file.
you cannot take this from existing phone. no software is able to read HDR password from phone.
Thanks Bhai for such a prompt reply.
It means that for Data , I need to rely on seller , who otherwise costing INR1000/- for flash/program.
You can take data dump from him and do it your self for free.
Posted using Moto G on Reliance CDMA
He refuse to give data dump.He is saying that he doesn't have data dump & will do it by another way. I am at the stake and can't do nothing except pay him.
