Akhilesh Chowdary Bojedla
How to: Calculate 26 digit A-key dec using CDMA workshop or DFS Lite
By cdmaworkshop:
Step 1: open cdmaworkshop (in my case i used cdmaworkshop 2.7)and go to cave tab.
Step2: Now in akey calulator section you will find 3 columbs namely dec,hex and esn.
Step 3: Now enter 12345678901234567890 in dec column.
Step 4: If you know the pesn of handset then put it directly in esn column.
If you dont know pesn go to www.esnconverter.com and conver your hex or dec meid and you will get pesn there
Step 5: now click on calc in checksum section and you will get a six digit number.
Now your 26digit akey is ready and good to go
Akey: 12345678901234567890 followed by 6 digit number you got from cdmaworkshop.
Hope it helps. Thank you.
  • Like 4
Trying this tonight
Hope this works
This will work.
And sometimes, you have options within the phone to enter the Akey through programming menu.
So you don't need low-level access for the handset through CW/DFS.
Trying this tonight
Hope this works
For you its not going to work, problem is you don't know your phones akey . What you will calculate?
Use auto program in FF ! limit is incresed !
tapatalking.....
The o/p posted common akey dec.unit. it can be changed from the person to person who registers the meid.
In this case its 12345678901234567890 but in some cases it can be 1212121212.......etc
So it is better to take akey from ur seller/meid registrator.
Also make sure to get support of flashphone suppport inorder to eliminate this steps.
Sent from my VS950 4G using Tapatalk 2
well I just said that 12345678901234567890 is a common akey dec value while registering meid. It can be changed to others as well during registering ur meid.
Even Flashphone doesnt support few phones its better to take akey from seller or meid registrator to avoid further confusion
For ex:- If ur meid registrator has registered ur meid by using 1212121.... and u calculate it as 12345.....0123...0 then ur phone will not work.
Apart from this great post Akhileshji to help out the newbies :)
Note for others:
Dont forget to ask akey from ur meid registrator or seller
The akey decimal value may differ from ur seller or meid registrator.
12345678901234567890 akey dec.value is widely used so it is common (around 99% it is used).
:previous:
Thats what this post is all about hitesh bhai. He don't know his phones akey and this post explains how to calculate it... And yes FF Can be used.. Undoubtedly its a great software... :)
This post only explains you how to get 26digit akey from 20digit dec , or from hex.
but problem was he was not knowing his original akey and none of default akey was working for him.
in this case nothing is going to help , unless original person who did registration gives actual akey.
he was lucky that his meid was supported by FF, other wise he need to contact original meid registration person.
Trying this tonight
Hope this works
If the akey is not working to you. Theres a trick that worked for me.
Factory reset the phone. It worked for me on an lg phone in which i was facing the same issue. I don't remember the model number though...
:previous:
Ohk.. Got it..
Trying this tonight
Hope this works
tapatalking.....
Autoprogram in FF worked
call disconnect issue resolved
Thanks Hitesh
I have an iPhone 4 from Verizon.
I have programmed it to reliance and done everything.
I have done the manual PRL change method.
I am facing problems with Akey as I don't have the correct akey.
I have tried
01234567890123456789
12121212121212121212
I am not able to contact the MEID Registerer.
He is not contactable.
My calls are getting disconnected and when called to the number from other phone
it says "NOT REACHABLE/OUT OF COVERAGE AREA".
So with research found its an akey problem.
I have got the no. transferred via MDN Transfer and have done Manual NAM Programming.
Maybe the FlashPhone Software can help or so.
Can anyone please provide me.
Please help.
I have tried
Please help.
use cdma workshop go un cave tab enter your akey and esn.and count check sum of your meid =akey+esn.
Enter this 16 digit akey in your iphone.it will work .
Sent from my SCH-I200 using Tapatalk 2
