3d1
Reliance CDMA Network Problem on Moto G CDMA
I Am Facing Problem With Moto G Reliance CDMA
Some Time I Have 3G Data And I Can Call Also
But When Someone Call Me It's Show Unreachable
But Reliance Network Is There And I Can Use Internet Also Or I Can Call Also Someone Without Hassle
Is That Problem With My Moto G Or Reliance Network Is Like That Only
I Live In Bangalore
:previous:
Your data is not configured properly, once you disable mobile data you would be able to receive calls.
Pls read post 136 by Hitesh to resolve this issue.
Noop
If I Disable Data Still Network Say Not Reachable Only But I Can Able To Call Anyone But Not Getting Call Same Time
And My Network Name Say Motorola Curious If Any Way To Change To Reliance ?
Dose it says not reachable or its off ?
Check IMSI in dfs .
Or I can check online
Sent by Moto G on Reliance CDMA
Opps
At Office It's Working But Still Same Problem At Home Not Reachable Msg If I Try To Call My No But Out Going And Data Work Good
Hitesh Bhai Help :)
Edited by 3d1
Can u check signals strength at home in 1x and ev
Screenshots will be helpful .
Compare them with office data .
And ping me after 9 for checking it online.
@3D1
Hope your problem is solved,
do confirm.
Hello
I installed update now no network
tried to write reliance prl it is successful still no network
Please solve my phone is off due to this
No network or no calls, as only PRL is required for getting signals .
Check your min if no calls .
If no network then check PRL again
Dear friends
Need a help. Earlier I was facing evdo issue and call sms & 1x data was working fine.
Now when I factory formatted the handset, and reflashed NAM, PRL, AKEY, NV items etc, evdo is working fine, but there is no network (call & sms not working). Please suggest possible solution. I will be really grateful.
PRL has been written successfully, but still there is no network(phone shows out of service).
Thanks & Regards
Sanjay
Sent from my Evo Design 4G
I am able to see signal bars, but when try to call it says no network. Surprisingly I can use EVDO for surfing, mail etc. Please help to restore call/sms
Dear friends , I did it. No network issue was because of NID/SID was locked. When I unlocked /freed it thru DFS network resumed.
Can you please elaborate on how to go about unlocking through DFS?
Is it bootloader unlock or some other unlock?
My Droid Maxx stopped working after I did a factory reset.
It shows "Reliance " at the bottom of the lock screen, but the signal icon has a red circle in it now. Earlier there was signal and 1x data working.
In DFS, go to nid/SID column. There are two such columns. In first column we feed the nid/SID parameters and just right side column is nid/SID lock column. In lock column put all value 0. That's it
I have registered to rimweb.in
i am new to smartphones. i bought a moto g reliance cdma from ebay.
which by mistakely reset it.
due to which network as lost.
when contacted the seller he said ur PRL has change to 61010 which
should have been 5.
am not able to understand how correct it pls help me out. thanks in advance.
regards,
anurag mahadik
Edited by mahadik.anurag
Check PRL, if PRL is correct , check if its enabled or not. Or check SID nid
should have been 5.
regards,
anurag mahadik
^^its prl issue.. write prl again and it will be done..
Not only PRL , data settings need to be done.
Now he is following moto g guide.
If possible help him on TV
hhii pulkit can u help me trough team viewer????
sure i will..
@mahadik.anurag ping me on gtalk id: pulkitgupta3195@gmail.com
you can ping me too at sanju.barc@gmail.com if required
I will suggest all guys to root the phone and freez the ota app through Titanium Backup. This will solve any future mess with RCDMA programming.
Hiteshji Bhai I odd all setting as per your valuable guidance but I am not able to use evdo hsd internet service only 1x working
Please guide me how to use evdo data
Re-write NV dump, Problem will be solved. Worked for me for the same issue you are facing.
