Kalaichelvi 14 Report post Posted May 6, 2014 Hi All, I have a Samsung Galaxy Note 3 Sprint. I have flashed the handset for reliance and i have data and everything working. Due to some issues in the handset, i factory reset it . After factory reset, the PRL and MIN sticks, i am able to make calls and sms , DATA doesnt work .When i try to connect the phone to system to write the NV Dump file, its not detecting the phone It keeps on saying USB device not recognized. Please let me know how to fix this ? .. Even MTP is not working Help me. Share this post Link to post Share on other sites
phonegeek 588 Report post Posted May 6, 2014 Check the data cable and drivers. Sent from my LG-LS980 using Tapatalk Share this post Link to post Share on other sites
st_7 138 Report post Posted May 6, 2014 Use different ports available or even try it on another computer, ofcourse you need to make sure that the cable isn't the fault at first(or any loose connections). Share this post Link to post Share on other sites
astrokidvaibhav 37 Report post Posted May 6, 2014 uninstall and re-install drivers.. Or uninstall device from device manager by right click menu and then reconnect to pc using usb cable.. Share this post Link to post Share on other sites
ev1lb0ygen1us 27 Report post Posted May 6, 2014 Try it on another PC. check first if MTP is working. If not, cable issue! Share this post Link to post Share on other sites
ankurcshah 112 Report post Posted May 6, 2014 Windows 7 or 8?? Sent from my LG-LS980 Share this post Link to post Share on other sites
Kalaichelvi 14 Report post Posted May 6, 2014 There is no issue with the cable , its working fine with my samsung stellar. When i connect the Note 3 to system , its getting charged, thats the only operations happening. Other than that, No MTP or diag. I literally tried, everything from reset to uninstall drivers to re-installing OS even no luck . I did i bricked my device ? .. or something wrong with my USB port ? I tried to reflash the OS my putting in ODIN mode, there was USB not detected. Is there any way to freshly flash the rom without ODIN mode ? Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted May 6, 2014 mostly looks like your phone's usb port is not working properly. clean it with good brush and check again. same issue was there in one lot of s2 gsm. 1 Share this post Link to post Share on other sites
bigbyte 24 Report post Posted May 7, 2014 There is no issue with the cable , its working fine with my samsung stellar. When i connect the Note 3 to system , its getting charged, thats the only operations happening. You said the same cable is working with Stellar, that means you are using the older USB 2.0 cable. Try using the original Note 3 cable, which is USB 3.0 type and I hope that you won't face any issues. Share this post Link to post Share on other sites
Kalaichelvi 14 Report post Posted May 8, 2014 Tried with the original cable ... Still No luck. ... Can any one tell me, is there a way to write the NV dumps or EVDO parameters to the phone without datacable ? Is there any applications for it ? or in the system level can we update this any place ? let me know. Share this post Link to post Share on other sites
phonegeek 588 Report post Posted May 8, 2014 Unfortunately, you need system to flash the files. As hiteshji suggested, the usb port is not working properly. You need to get it repaired. Sent from my LG-LS980 using Tapatalk Share this post Link to post Share on other sites
Kalaichelvi 14 Report post Posted May 8, 2014 The only doubt i have is , my phone can charge via datacable and mains ... But when i want to connect to DM or MTP there is no response. Going to samsung service center to change the port. Will keep you posted. Share this post Link to post Share on other sites
phonegeek 588 Report post Posted May 14, 2014 Any update? Share this post Link to post Share on other sites
Kalaichelvi 14 Report post Posted May 27, 2014 Got it repaired from Samsung Store locally. Was able to access DIAG now , thanks too all suggestions .My device is currently in 4.4.2 .Is there any way to make it OMH.? ... Please assist .. thanks, Share this post Link to post Share on other sites
santanu@impaq 16 Report post Posted May 27, 2014 Check the other Note 3 thread. Making it work with OMH is quite simple. That too on 4.4.2 Share this post Link to post Share on other sites
