argee2014
Call divert on Reliance GSM
I am trying to figure out if i can divert calls from a reliance gsm mobile from delhi circle to rajasthan reliance gsm mobile.
call divert on reliance GSM from say Delhi Circle to Rajasthan circle same network?
If anyone can test and confirm.
Argee
I guess call diver only happens in the same Circle and not across circles.
Argee
Call divert is only possible within your circle only.
Read following text on webpage >> http://www.rcom.co.in/Rcom/personal/postpaid/cms.html#an4
Staying in touch When you are unable to take calls, use Call Divert to direct your calls to another phone number or voicemail box within your circle. Your every single incoming call is noted – no matter if you are in a meeting, travelling, in an area with no coverage or out of battery.
If U r in roaming circle say delhi number in Rajasthan than u can divert calls on Rajasthan number
