ankurcshah
CDMA REV B handsets?
Hello fellow members. I wanted to know what all options do we have in the revolution b area of handsets? . Since meid registration is closed now its only the omh supported phones which will work. So what all are the phones that support omh, rev b and lte as well?. Pls give us your inputs. It would be helpful for fellow members like us.
Sent from my SPH-L900 using Tapatalk 2
HTC Desire 816, 700, and 601 Supports Rev B.
No handsets for Indian LTE + EVDO as of now
Any of the Samsung ones? What about the note 3? Does it support lte or rev b?
Swipe sonic claims to support 9.1 mbps. which seems only possible if its Rev.B
any new rev b handset with
min Screen PPI >256
Min RAM 1GB
Min Memory 16GB.
LG tribute or desire 510 let down me with only 4 gb memory and Low Screen Resolution.
The only one handset available in India with OMH EVDO Rev.B and 3G GSM is "ZTE Grand SII". Specification is very good with 1080p Full HD (FHD) 5.5-inch Screen, 2GB RAM and 16GB ROM etc. For details please visit the following link http://www.amazon.in/ZTE-P897A21-Grand-SII-Silver/dp/B00PLHU6AQ/ref=sr_1_1?ie=UTF8&qid=1432316684&sr=8-1&keywords=ZTE+Grand+SII#productDetails
:previous: The above handset supports CDMA and GSM, but it is a single SIM handset. Can use as a 3G CDMA phone using a CDMA OMH RUIM or can use as 3G phone using a 3G GSM SIM. Not possible to use as CDMA+GSM dual sim phone.
Edited by KAPILKDEV
Re : EVDO Rev B. I think if Budget Permits Better go for HTC One E8 . Its the best for REV. B IMHO
I am using HTC one Dual Sim. Works with Rev.B and GSM both together.
need Some review as well as buying links
Shortlisted
Zte grand s2
Htc desire 816 CDMA+GSM
HTc one M7
Any User of Grand s2 can provide a short review/ or link for good review.
Not able to find Desire 816 cdma+gsm and htc one m7 cdma
especially on ebay there is none available.
Please help..
261 reviews of grand s2 available at amazon.
Oh aditya ji, I have read those reviews.
while the star rating is good but some reviews are really bad.
I am now more inclined towards HTC M7 rev b.
Not finding a budget (13-14k) listing on ebay.
motorola post-83039-143299642372_thumb.pngdroid Maxx supporting evdo rev B networks today only I configured through dfs tools...
motorola attachicon.gifScreenshot_2015-05-30-10-02-42.pngdroid Maxx supporting evdo rev B networks today only I configured through dfs tools...
how did you make it stick to NV only mode......for me it always resetted to ruim_only mode on reboot
That's such a lovely news, it's not all that hopeless. As in for quite sometime I thought no rev b and 4g support on this one.
Then I had made this post that the chipset supports it.
http://www.rimweb.in/forums/index.php?/topic/37005-Motorola-Droid-4.4.4-update-locks-cdma-ruim-support,-Do-Not-update.#entry318552
Can you please mention the steps you did in dfs?
In DFS Tools,setting HDR SCP force AT config to -> RevB_MFPA
and
[0] Sub2 PL <- enable
[1] EC CH <- enable
[2] EA CH <- enable
[3] EFT CH <- enable
[4] Sub 3 RT <- enable
[5] Sub 1 RT <- enable
[6] Enh Idle <- enable
[7] Gen M-M <- enable
BCMS [0] <- enable
App Sub MFPA <- enable
I'm getting a good speed also without any other packs it always in the range of 4 to 5 mbps
  • Like 3
Just a noob question. Does us cellular note 2 nv based handset supports with rev b?
And if yes will above settings help get this speed
Which City ?
I think our system version differs as my status shows less details. I have done the settings but need 3rd party app to check signal type
How to connect droid ultra xt 1080 to dfs I mean how to enbale Diag mode on droid ultra
Shut down then start while pressing volume down. Release after few seconds. In menu choose bptools.
That's it, it will boot again in diag mode now
Which City ?
pune
I am using advanced signal status from play store for this .
Edited by pentagan
