SmartSamrat
JailBreak Available For iOS 7.1.1 and 7.1
Now Only Avail on Windows Platform
Jailbreak released by Chinese Developer so Jailbreak Soft in Chinese.
http://pangu.io/
Method for jailbreak
How to jailbreak iOS 7.1.x with Pangu for Windows
Step 1: Download the latest version of Pangu from http://pangu.io/
Step 2: Plug your iOS 7.1.x device in to your computer’s USB port
Step 3: Run Pangu_v1.0.exe on your Windows machine. If you see weird characters, it may be due to Windows not displaying the Chinese character-set correctly. Simply follow along in our video above to see what we mean.
Step 4: Make sure the checkbox is unchecked, and click the Start Jailbreak button.
Step 5: Pangu will ask you to go to Settings > General > Date & Time and disable the Set Automatically toggle. You will then need to set the date to June 2, 2014.
Step 6: The jailbreak process will start. Eventually you will see the Pangu app icon on the Home screen. Tap the Pangu icon to launch the Pangu app.
Step 7: Wait patiently, and the jailbreak will process. The video tutorial is sped up, the whole process takes about 10-15 minutes, so be patient.
Step 8: Once the jailbreak is completed, you should see a “enjoy your new jailbreak message”. Unlock your device, and you should see Cydia on the Home screen.
Congratulations. You now have an untethered jailbreak on iOS 7.1.x. Pangu should automatically set your date setting in Settings > General > Date & Time back to Set Automatically.
Good News For Sprint iPhone 5s and 5c now they can use fully function iphone using Rsim Air2 and Mini2.
  • Like 3
Now available in English and for Mac also
Sent from my VS980 4G using Tapatalk
Apple have released 7.1.2 with patch for loophole.
7.1.2 jailbreak possible just did it
U did updates via itunes or ota updates. Share the link to file for jailbreak
Yes pangu works with 7.1.2 ota
Just used it yesterday on my iPad Air.
Edited by ::: VA :::
I have been desperately wanting to have pwntunes? Can anybody help me?
Guys I tried to jailbreak my ipod touch 5 running 7.1.1 using pangu but after the reboot the jailbreak fails. I used pangu 1.2.1
any solutions ?
any solutions ?
Try it again. I used pangu 1.1 on iPod touch 5 with 7.1.2 and it works without problem.
Sometimes in one go it doesn't work.
I tried more than 5 times I fear it might fry up my iPod touch
I hope you changed the date when it asks on screen. Then after a restart it asks you to click pangu icon on your device too ......
Hope you did both steps as when asked.
Yes sir
Hard luck for you. I have JB three devices with pangu so far without any issue.
