rishiburman 0 Report post Posted May 9, 2005 I have a LG 2030 . I am trying to connect to the internet using the phone to my laptop . I have purchased a LG2030 USB data cable . I install the R connect LG2030 serial to USB driver and then restart the computer. When i connect the cable to my USB port , it does not prompt for the new hardware wizard. It just shows that the USB device is not recognised .When i try updating the driver manually it says it cannot find the driver ( I downloaded the driver from the reliance web site) . I tried to install the same on someone else's laptop ., still the same error . Just says "USB device not recognised ". Do i need to have a serial port ? is it mandatory . Is some special software required to be preinstalled before I install this LG 2030 driver . I have Windows XP professsional . Please help . Share this post Link to post Share on other sites
Arun 795 Report post Posted May 11, 2005 This can happen if the connector in the data cable is corrupt or if the USB port in the computer is damaged. Share this post Link to post Share on other sites
