dr.faramroze 703 Report post Posted July 7, 2014 (edited) Verizon's Novatel, ZTE and Pantech pocket routers are very popular in US. Initially, Novatel 2200 Jetpacks were based on NV mode programming only. Now the newer Novatel 4510, 4620L, 4620LE and 5510 are based on CDMA SIM slots. The ZTE 890L and Novatel 4620L/LE are global mode MiFi devices where any GSM SIM will work on the go. While Reliance 1x works instantly upon SIM insertion, Evdo does not connect and needs to be tweaked a little. And data on Tata Indicom does not work without these tweaks. Requirements for Reliance CDMA EVDO on SIM:- 1. We have to know the 8 digit HDR password of the RUIM before begining the process. 2. Download 4620L drivers. 3. Mifi should start installing various ports after installation of the driver 4. Using DFS, connect to status port and send SPC 000000 (the Jetpacks do not listen without this port) 5. Do not read or change any settings 6. Go to data and in HDR UID/Pass write A10000xxx@ in your HDR username, and the RUIM's 8 digit password in the password field. 7. Go to MIP section, without reading write A10000xxx or 'net' in the first profile, same in the RM NAI. 8. Reboot 9. Insert SIM and 3G connected. Requirements and procedure for EVDO on Tata Indicom Photon SIM:- 1. Using DFS, send SPC 000000 and go to MIP profile, enter 'internet' in the first profile and reboot. 2. After this change, any Tata SIM can be used since it has a universal MIP, unlike Reliance. (Any data pack with any denomination works) Note:- This is only for CDMA band of the Mifi. Router configuration is done by wifi by vz.hotspot or . GSM_WCDMA is global auto APN. ZTE 890L is fully unlocked and does not require any tweaking. This tutorial pertains to 4620L, 4620LE and 5510. None tested on MTS. Important update:- For Reliance, universal username/pass = net/net working for evdo on some firmwares and some firmwares need HDR username A1000xxx@hrpd.xxxx in first MIP profile in DFS and nothing else. HDR password is no longer required to work. Mifi4620_Drivers.zip Edited July 9, 2014 by dr.faramroze 10 Share this post Link to post Share on other sites
kshah 452 Report post Posted July 7, 2014 THANKS how to read HDR pass of RUIM? Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted July 7, 2014 Sprint Note 2 L900 on 4.1.1 shows hdr pw when connected to a sim tray. Samsung Galaxy Axiom on 4.0.4 shows hdr password of the sim. Other phones can read thru root and via logcat. Sent from Samsung Note 3 N900P 3 Share this post Link to post Share on other sites
jagadams 0 Report post Posted January 4, 2015 can you please elaborate on the prodecure to use logcat on s3 (r530) Share this post Link to post Share on other sites
