::Hitesh::
[need info] One Way Sync of Files
I am looking for a utility / app which can pull files from FTP server and save to a local folder.
as soon as any changes happen on FTP folder this app should pull data from FTP folder and save to local drive.
it is something like drop-box but only server to local pc
no reverse sync require.
Also destination folder on local drive will have many files, which should not be touched, only overwriting is permeated
any free or paid app for same type of use ?
or any one can write a small app for doing this ?
if require i can buy a FTP server or we can use many free to use cloud storage like dropbox, gdrive, cubby etc..
looking for some suggestions.
Hitesh bhai,
Try WinSCP, as per the documentation http://winscp.net/eng/docs/faq_keep_local_up_to_date it can be done, It is easy please refer to this screen shot http://winscp.net/eng/docs/ui_synchronize for more info.
I have not tried this feature of WinSCP, hopefully it will serve your purpose.
Thanks,
thanks for suggestion, Had read about WinSCP but it is too much of work compare to watchFTP.
working on a workaround using dropbox and folder replicator dsynchronize
I've bought goodsync... It has lot of possibilities.. Just go to it
Sent from my LG-LS980 using Tapatalk
Check rsync. It is little complicated but very good and do exactly what you want. Their web site http://rsync.samba.org/
