::Hitesh:: 1,763 Report post Posted September 6, 2014 I am working on small charity project, I have a AS/HTMLP page which have embed media player object , file name is trigger by another software. As of now with below code I am able to play the video correctly without any issues. this is running on local IIS server installed on windows XP-SP3. Only problem is I want to play these videos in full screen without user clicking any buttons or link. video plays almost full screen but shows tracker and controls I want to hide these tracker and control and make it true full screen. system = windows xp 32bit SP3 / IE-6 / WMP-9 <html><head><script>function hideScrollBar(){document.body.style.overflow = 'hidden';}</script><title>Commercial</title><meta name="Microsoft Theme" content="copy-of-zero 000, default"></head><body onLoad="hideScrollBar()"><%l_fileName = Request.QueryString("FileName")l_vol=Request.QueryString("Vol")if IsNull(l_vol) thenl_vol="-1" end if if IsNull(l_fileName) thenResponse.write "No MPG File Provided"elsel_ext = UCase(Right(l_fileName, 4))if IsNull(l_ext) thenResponse.write "Less than 4 characters in Extension"elseif (l_ext = ".BMP") or (l_ext = ".JPG") or (l_ext = ".GIF") then%><img src="<% Response.write l_fileName %>" height="100%" width="100%"></img><%else%> <object id="mediaplayer" classid="clsid:22d6f312-b0f6-11d0-94ab-0080c74c7e95" codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#version=5,1,52,701" standby="loading microsoft windows media player components..." type="application/x-oleobject" width="1024" height="790"><param name="filename" value="<% Response.write l_fileName%>"><param name="animationatstart" value="false"><param name="transparentatstart" value="true"><param name="autostart" value="true"><param name="showcontrols" value="false"><param name="ShowStatusBar" value="false"><param name="windowlessvideo" value="true"><embed src="<% Response.write l_fileName%>" autostart="true" showcontrols="false" showstatusbar="0" bgcolor="black"width="1024" height="790"></object><%end ifend ifend if%> </body></html> Share this post Link to post Share on other sites
digitalnirvana 646 Report post Posted September 8, 2014 (edited) Instead of width="1024" height="790" try width="100%" height="100%" in both <object> and </object> see if it works? e.g. <div style="position: fixed; z-index: 9999; width: 100%; height: 100%"> <iframe frameborder="0" height="100%" width="100%" src="www.youtube.com/embed/pfHxl46KyZM? rel=0&autoplay=1&controls=0&loshowinfo=0&autohide=1"> </iframe> </div> Edited September 8, 2014 by digitalnirvana 1 Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted September 9, 2014 Thanks for suggestion, but HxW it self is too small to become full screen , so I have to set a size of screen (1024*768+) , this way I get almost full screens but controls (tracker + play stop buttons ) won't go. By increasing height to 780 approx controls goes out of screen. But still it's not perfect full screen. Got the solution :- if you see I was using classid of WMP 6.4, this code works well on win2k systems with wmp6.4 as native default. But in xp by default it is 7+, and with sp2/3 it's wmp9. From wmp7 onwords classid of wmp changed . after changing the classid I was able to use parameters like full screen and ui.mode=none. This did the trick and now it is playing in full screen without any issues. Will post the full code if some one needs it in future. Posted by Moto G on Reliance CDMA 1 Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted September 10, 2014 <html> <head> <script> function hideScrollBar() { document.body.style.overflow = 'hidden'; } </script> <title>Commercial</title> </head> <body onLoad="hideScrollBar()" bgcolor="#000000"> <% l_fileName = Request.QueryString("FileName") l_vol=Request.QueryString("Vol") if IsNull(l_vol) then l_vol="-1" end if if IsNull(l_fileName) then Response.write "No MPG File Provided" else l_ext = UCase(Right(l_fileName, 4)) if IsNull(l_ext) then Response.write "Less than 4 characters in Extension" else if (l_ext = ".BMP") or (l_ext = ".JPG") or (l_ext = ".GIF") then %> <img src="<% Response.write l_fileName %>" height="145%" width="150%"></img> <% else %> <object height="100%" width="100%" classid="CLSID:6BF52A52-394A-11D3-B153-00C04F79FAA6" id="MediaPlayer1" style="float: top"> <param name="URL" value="<% Response.write l_fileName %>"> <param name="rate" value="1"> <param name="balance" value="0"> <param name="currentPosition" value="0"> <param name="defaultFrame" value=""> <param name="playCount" value="1"> <param name="autoStart" value="-1"> <param name="currentMarker" value="0"> <param name="invokeURLs" value="0"> <param name="baseURL" value=""> <param name="volume" value="100"> <param name="mute" value="0"> <param name="uiMode" value="none"> <param name="stretchToFit" value="-1"> <param name="windowlessVideo" value="-1"> <param name="enabled" value="0"> <param name="enableContextMenu" value="-1"> <param name="fullScreen" value="-1"> <param name="SAMIStyle" value=""> <param name="SAMILang" value=""> <param name="SAMIFilename" value=""> <param name="captioningID" value=""> <param name="enableErrorDialogs" value="0"> </object> <% end if end if end if %> </body> </html> Share this post Link to post Share on other sites
