BB_user 0 Report post Posted September 17, 2014 Hi, I have recently got an imported 9930 Verizon (GSM Uncloked) handset. Got hold of a techie to load PRL (I guess using CDMA workshop) and registered ESN with tata, unfortunately he didn't do a good job. I couldn't activate using *228 (OTA), it throwing some error. But some how VOICE calls are working and SMS (receiving SMS but not able to send SMS). Initially they (TATA team, & Techie) both promised that BIS will be activated but now they are giving some lame reasons to activate. On other TATA Blackberry helpdesk is trying to register my MEID from past three weeks and failed to activate it. Yet they are giving some excuses that their IT team is working on the problem. How to fix BIS activation?? Should I hard reset my device to register this MEID with Reliance (because initially before PRL load *228 was able reach Reliance) - After PRL loading I can't hear Reliance / either Tata - It's just saying Welcome thank you for using our services Is there a fix for OTA to reach Tata? Or Can I switch other Service provider (GSM) and use Engg screen options to activate BIS - Is it really possible?? What is A-Key on CDMA Screen? How to get it? Would it help in any way to fix this issue?? ##000000 - Is showing some verizon related info. Can I get similar info for TATA . Would it help?? MSL (from service provider)—??? MDN (from service provider)—?? IMSI_S (from service provider) - ?? SIP-ID (from service provider)—?? SIP-Password (from service provider)—?? MIP-ID (from service provider)—?? MIP-Password (from service provider)—?? SID (from modem card)—?? NID (from modem card)—?? DMU MN Auth- ?? Primary HA Address?? Secondary HA Address?? Thanks in advance for your help....! Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted September 18, 2014 if your calls and sms is working , be happy BIS might not possible, TATA // Reliance dont do it normally. you can ask them to start normal data, minimum 1x is possible. Share this post Link to post Share on other sites
BB_user 0 Report post Posted September 18, 2014 SMS is still not a complete solution. At times I can send to some service provider users but not all. 1X is shown on my phone but still no data is active. On the other hand under mobile networks it is still showing Verizon wireless not Tata. Should I hard reset and follow a proper method to get this done methodically, in order to activate all features properly?? Thanks!! Share this post Link to post Share on other sites
::Hitesh:: 1,763 Report post Posted September 18, 2014 Do not hard reset , you might your self in deeper issues. It is going yo show Verizon for life long, no one can make it show tata. There are methods but not recommend. And dose not make any differences. For sms set your country to India. Also check sending sms with +91 or 0 in starting of number. 1x can be done by your "techie" guy, its not that difficult. Posted using Moto G on Reliance CDMA Share this post Link to post Share on other sites
