Dj 25 Report post Posted November 20, 2014 So the case in point is extremely poor reception in the basement and groundfloor of my new workshop. Outside of it, cell signals return to normal and get all 5 bars. The closest tower is like 300m away. Has anyone here used one of these singal booster kits? Please point me in the direction... any reviews or suggestions welcome... Share this post Link to post Share on other sites
rohitgaur 78 Report post Posted November 21, 2014 I had the same problem and I have used a ZBoost Kit from Ebay.com It works and I have used all R CDMA phones in my house http://www.ebay.com/itm/zBoost-YX545-SOHO-Dual-Band-Cell-Phone-Signal-Booster-for-home-or-office-/261657413150 1 Share this post Link to post Share on other sites
Dj 25 Report post Posted November 21, 2014 Thanks rohit... can i call you? Couple of queries... how much did it end up costing all inclusive and does it work for evdo as well? Are the external antennas included as well? It says its dual band and supports gsm too? Did u try that? Share this post Link to post Share on other sites
rohitgaur 78 Report post Posted November 21, 2014 (edited) Pls call me on 9356661616.....Not working with GSM, EVDO and CDMA work great Over the past 3 years, I had to buy LOcal power adapters costing approx 150 Rs, since the Booster stays on for 24X7 External Antenna, 50 Ft Cable etc are included, Though I use a longer Cable(Got the Tata Sky Guy to Lay and crimp for Rs 300) since my cable had to come from 3 storeys high to ground floor I paid approx 15 K through ebay Global Buy Edited November 21, 2014 by rohitgaur 4 Share this post Link to post Share on other sites
parin 857 Report post Posted December 5, 2014 Dj since you have it now You can also review on booster ️️️ Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
vakharia 23 Report post Posted May 28, 2015 I am interested in the boosters. Can someone help me with a link to some reviews? Share this post Link to post Share on other sites
Dj 25 Report post Posted May 29, 2015 I am using it currently and it works flawlessly. Got it for hetaldp and otgers too who are using it as well. If u need one get in touch will get one for u Share this post Link to post Share on other sites
vakharia 23 Report post Posted May 29, 2015 Please provide more information. Is there a product available locally and with support? Or is this just an imported item? Also, does it just help in voice calls or does it also increase data speed? Share this post Link to post Share on other sites
ashishsethi 55 Report post Posted May 30, 2015 I'm interested too. CDMA signal goes to 1 bar or zero when I enter my house. Share this post Link to post Share on other sites
