pbananth 1 Report post Posted December 5, 2014 Recently purchased this cdma/ gsm world phone. Android 4.4.2 Works fine. But some problem 1. When call comes it shows the current location and number. Not names.. 2. When using "Hotspot".when incoming call comes, the "hotspot" shutting down. This is very awkward. Again I should manually restart the hotspot. In s2 the data connection will be lost but the hotspot will always on. Is there is any solution or rOM? Gurus help.. Thanks. Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
rawda 8 Report post Posted December 7, 2014 Install full screen caller id from playstore or install call popout to display name 1 Share this post Link to post Share on other sites
pbananth 1 Report post Posted December 7, 2014 Thanks.. Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
rawda 8 Report post Posted December 20, 2014 Install full screen caller id from playstore or install call popout to display name I have updated phone to 4.4.4 now cdma data dont work on s5 sprint anyone facing same problem? Any solution? Can I downgrade to 4.4.2 Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted December 20, 2014 Install full screen caller id from playstore or install call popout to display name I have updated phone to 4.4.4 now cdma data dont work on s5 sprint anyone facing same problem? Any solution? Can I downgrade to 4.4.2 You need to configure using DFS again from scratch. Possibly after doing ##786#. RTN will erase all settings and data. Share this post Link to post Share on other sites
rawda 8 Report post Posted December 21, 2014 Install full screen caller id from playstore or install call popout to display name I have updated phone to 4.4.4 now cdma data dont work on s5 sprint anyone facing same problem? Any solution? Can I downgrade to 4.4.2 You need to configure using DFS again from scratch. Possibly after doing ##786#. RTN will erase all settings and data. Hi I found the reason if you put a RG series sim in s5 data stops working, Now even after ##786# some settings are not removed, Data dont work on cdma now Share this post Link to post Share on other sites
vipsy6 4 Report post Posted February 10, 2015 Install full screen caller id from playstore or install call popout to display name I have updated phone to 4.4.4 now cdma data dont work on s5 sprint anyone facing same problem? Any solution? Can I downgrade to 4.4.2 You need to configure using DFS again from scratch. Possibly after doing ##786#. RTN will erase all settings and data. Can you please elaborate "from scratch" ? Share this post Link to post Share on other sites
mitulsoni22 1 Report post Posted April 28, 2015 Hello purchased this handset sprint spark sm g900P Cdma/gdm.past one month. evthing working fine. data also quite good. only issue is network with cdma.and no conference calling the signal keeps on fluctuating from 1 bar to 5 bars. coudlnt get a stable signal. Sometimes goes to no bar. tried reseting with Network reset code, tried changing sim card. (Current series RECRUCO160) but all in vain. Gsm network quite stable and works fine Can plz gurus help me..whats d matter..how can I overcome it. Share this post Link to post Share on other sites
Gdeepp Sran 2 Report post Posted August 5, 2015 hello all galaxy s5 (Sprint )(G900P) user anybody have Debrick .img for galaxy s5 g900P i need it if any buddy on lollipop 5.0 u can create your selp and send me gdeepp@gmail.com how to make Debrick .img You need to be rooted and have busybox installed!Simply run this command as root and upload the image to mebusybox dd if=/dev/block/mmcblk0 of=/sdcard/200MB.img bs=4096 count=50000 if = not work then use - instead of = thanks Share this post Link to post Share on other sites
