nitinmukesh123 11 Report post Posted December 9, 2014 Hi, Please help me with this. I want to move contacts, messages and whatsapp from MI3 to oneplus one. Please advice an easy method to do so. Thanks Share this post Link to post Share on other sites
kalpeshaparmar 66 Report post Posted December 9, 2014 I used Google for Contacts, SmS Backup & restore for sms... & for Contacts one more sms back up application is there... But it couldn't Restore by sms... And for WhatsApp data & other files I used Computer.... Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted December 9, 2014 For contacts sync with Google, you need not do anything but making sure that they are synced with Google servers in old phone. For sms use sms backup and restore app from playstore. There is another such app for Whatsapp, or even there is an option to backup chats in Whatsapp too. For game score and backup settings of other apps use Titanium backup... Sent from my OnePlus One using Tapatalk Share this post Link to post Share on other sites
nitinmukesh123 11 Report post Posted December 9, 2014 Thank you guys for your suggestions. Do I need to have root access to use Titanium backup. Share this post Link to post Share on other sites
KanagaDeepan 1,084 Report post Posted December 9, 2014 ^^^^ Yes... Share this post Link to post Share on other sites
nitinmukesh123 11 Report post Posted December 12, 2014 I followed the steps as outlined in the following link to move Whatsapp to another phone however I am facingissue.https://www.whatsapp.com/faq/en/android/20902622 1. I stopped using whatsapp on MI3.2. I copied whatsapp folder from MI3 to 1+1 at the same location.3. I installed whatsapp on 1+1.4. On launching after validation process it picked up the backup and I cansee the messages. The issue I am facing is it is showing messages only till November, 22 and nottill today's date. I factory resetted the 1+1 phone and followed the stepsagain but same issue. Please could you help solve this issue. Share this post Link to post Share on other sites
kalpeshaparmar 66 Report post Posted December 12, 2014 On 12/12/2014 at 10:32 AM, nitinmukesh123 said: I followed the steps as outlined in the following link to move Whatsapp to another phone however I am facing issue. https://www.whatsapp.com/faq/en/android/20902622 1. I stopped using whatsapp on MI3. 2. I copied whatsapp folder from MI3 to 1+1 at the same location. 3. I installed whatsapp on 1+1. 4. On launching after validation process it picked up the backup and I can see the messages. The issue I am facing is it is showing messages only till November, 22 and not till today's date. I factory resetted the 1+1 phone and followed the steps again but same issue. Please could you help solve this issue. Even i faced the same problem but my data not being important didn't do much... You can try to delete the backup from old phone and make a new back up.. Then restore it on new 1+1... Share this post Link to post Share on other sites
nitinmukesh123 11 Report post Posted December 13, 2014 (edited) Issue fixed. I again took backup, deleted the whatsapp folder from 1+1 and moved the whatsapp folder to 1+1 deleted all files from datastore folder except the last backup file. Edited December 13, 2014 by nitinmukesh123 Share this post Link to post Share on other sites
ACS 130 Report post Posted January 10, 2015 Apart from Contacts (pretty obvious that a google account helps here), there's an app called "Copy my Data" in play store that helps the new phone communicate with your old, through the same Wifi network & you can selectively copy - Contacts, photos, videos & calendar. Whatsapp backup has already been discussed above.. Share this post Link to post Share on other sites
