tech.ba 2 Report post Posted January 15, 2016 so guys what is the status of verizon moto E XT1528 with 5.1 ?? will calls/sms/data work on cdma??Simple solution make Reliance CDMA worked on Verizon Moto E XT1528 Android 5.1 call/text/data on Reliance CDMA1.Buy RGE Sim Card 2.Mod The Sim 3.Put APN (net) 4.Done. 100% Working. I have moto 2 boost xt1526 With rim data not working with rec sim i can buy rge series sim Can u please tell me what is "mod the sim" Sent from my MI 4W using Tapatalk Share this post Link to post Share on other sites
Kapil Matey 28 Report post Posted January 16, 2016 so guys what is the status of verizon moto E XT1528 with 5.1 ?? will calls/sms/data work on cdma??Simple solution make Reliance CDMA worked on Verizon Moto E XT1528 Android 5.1 call/text/data on Reliance CDMA1.Buy RGE Sim Card 2.Mod The Sim 3.Put APN (net) 4.Done. 100% Working. I have moto 2 boost xt1526With rim data not working with rec sim i can buy rge series sim Can u please tell me what is "mod the sim" Sent from my MI 4W using Tapatalk Boost Moto E XT1526 is working out of the box with REC series...kindly change the sim... Share this post Link to post Share on other sites
jugnu_sidhu 0 Report post Posted January 19, 2016 so guys what is the status of verizon moto E XT1528 with 5.1 ?? will calls/sms/data work on cdma?? Simple solution make Reliance CDMA worked on Verizon Moto E XT1528 Android 5.1 call/text/data on Reliance CDMA 1.Buy RGE Sim Card 2.Mod The Sim 3.Put APN (net) 4.Done. 100% Working. Thank you Kapil for the feedback. A couple of comments. 1) Can you please confirm it is 3G EVDO / CDMA (3G1x) High Speed Data and not 2G data? 2) Can you please elaborate on Steps 2 and 3. What does "Mod The Sim" mean? Can you provide details for "Put APN"? What were the settings and what did you modify to make it work? Thank you so much. its working with 3G/EVDO.... PM me... can you help me with it too, i ported from airtel to relicance CDMA to get my XT1528 working Share this post Link to post Share on other sites
kenpet22 2 Report post Posted January 20, 2016 Mod the SIM is manually cut the SIM card as it is not a preCut SIM. Share this post Link to post Share on other sites
kenpet22 2 Report post Posted February 2, 2016 Folks, I haven't gotten Android 5.1 Moto E to work on Reliance with EVDO data. Kapil Matey is the only one I know who claims he has Moto E XT1528 (Verizon) working with EVDO data with Android 5.1 on Reliance. Please reach out to him if you need help. Thanks. Share this post Link to post Share on other sites
atishj 8 Report post Posted February 2, 2016 Any Body Help me on Xt1526, single issue is that when i put 4G idea sim on WCDMA/GSM mode it does not show coverage Share this post Link to post Share on other sites
Kapil Matey 28 Report post Posted February 2, 2016 Folks, I haven't gotten Android 5.1 Moto E to work on Reliance with EVDO data. Kapil Matey is the only one I know who claims he has Moto E XT1528 (Verizon) working with EVDO data with Android 5.1 on Reliance. Please reach out to him if you need help. Thanks. Mod the sim means set PrefMobileIP in DFS => Programming => Mobile IP Section Mod the SIM is manually cut the SIM card as it is not a preCut SIM. Mod the sim means set PrefMobileIP in DFS => Programming => Mobile IP Section 1 Share this post Link to post Share on other sites
kenpet22 2 Report post Posted February 3, 2016 Folks, I haven't gotten Android 5.1 Moto E to work on Reliance with EVDO data. Kapil Matey is the only one I know who claims he has Moto E XT1528 (Verizon) working with EVDO data with Android 5.1 on Reliance. Please reach out to him if you need help. Thanks. Mod the sim means set PrefMobileIP in DFS => Programming => Mobile IP Section Mod the SIM is manually cut the SIM card as it is not a preCut SIM. Mod the sim means set PrefMobileIP in DFS => Programming => Mobile IP Section Thank you Kapil. Verizon Moto E on 5.0.2 worked out of the box. But 5.1.x never worked (as reported in the forum) till Kapil claimed otherwise. Kapil, do you know what change between 5.0.2 and 5.1.x that required additional SIM modifications? I hope folks who got their devices working on 5.1 or 5.0.2 share their info. It will help the community at large. Thank you. Share this post Link to post Share on other sites
Saiesh 12 Report post Posted February 5, 2016 Kapil if you dont mind please post the detail procedure to get data working om Moto E 5.1 Share this post Link to post Share on other sites
bhoodarmal 3 Report post Posted February 14, 2016 I have Moto E XT1526 and have same issue as Moto E Xt1528. Above setting of Mod of SIM steps are needed to change in our phone as see whether CDMA get data working or not. Can Kapil post the steps to mod the sim ? Share this post Link to post Share on other sites
Guru Gopal 589 Report post Posted February 16, 2016 on XT1528 i got the data like this. I put the phone bptools connected to pc enabled usb debugging on phone loaded moto diagnostic drivers in device manager for the last XT item of unknown devices. OPEND the DFS and selected the port, given sent spc gone to programming, ip section changed simple ip to pref mobile ip total profiles one and active profile one. reset the phone and restarted the phone. entered apn manually and saved that's all, phone works with RGE sim data also APN parameters name = any apn=net username=net password=net mcc is 404 and mNc is 00 2 Share this post Link to post Share on other sites
moto_modx 1 Report post Posted February 24, 2016 Hello I am new to cdma forum, please suggest what is bptools. if it is a software what is the best way to get it? If it is licensed whom I can approach to, to use for one time. Anyone who can help out me in Pune for this procedure .. thanks Share this post Link to post Share on other sites
Guru Gopal 589 Report post Posted February 24, 2016 Hello I am new to cdma forum, please suggest what is bptools. if it is a software what is the best way to get it? If it is licensed whom I can approach to, to use for one time. Anyone who can help out me in Pune for this procedure .. thanks ha ha. if click power and vol - at one time (when the phone is in off position) it will boot in different screen you have to go to BP Tools with the help of vol + or -. 2 Share this post Link to post Share on other sites
Saiesh 12 Report post Posted February 27, 2016 on XT1528 i got the data like this. I put the phone bptools connected to pc enabled usb debugging on phone loaded moto diagnostic drivers in device manager for the last XT item of unknown devices. OPEND the DFS and selected the port, given sent spc gone to programming, ip section changed simple ip to pref mobile ip total profiles one and active profile one. reset the phone and restarted the phone. entered apn manually and saved that's all, phone works with RGE sim data also APN parameters name = any apn=net username=net password=net mcc is 404 and mNc is 00 Rge sim data works without any programming???Sent from my 2014818 using Tapatalk Share this post Link to post Share on other sites
prem2434 10 Report post Posted February 28, 2016 on XT1528 i got the data like this. I put the phone bptools connected to pc enabled usb debugging on phone loaded moto diagnostic drivers in device manager for the last XT item of unknown devices. OPEND the DFS and selected the port, given sent spc gone to programming, ip section changed simple ip to pref mobile ip total profiles one and active profile one. reset the phone and restarted the phone. entered apn manually and saved that's all, phone works with RGE sim data also APN parameters name = any apn=net username=net password=net mcc is 404 and mNc is 00 loaded moto diagnostic drivers in device manager for the last XT item of unknown devices entered into bttools and enbled usb debbuging, but how to install drivers? where to get moto diagnostick drivers ? Share this post Link to post Share on other sites
Saiesh 12 Report post Posted March 25, 2016 Request all u forum members to guide for the same in detail step by step. Sent from my 2014818 using Tapatalk Share this post Link to post Share on other sites
Guru Gopal 589 Report post Posted March 27, 2016 XT1528 Switch off the phone. power it with vol down switch together use vol + or - to go to BPtools click power button. Phone powers, connect to pc. enable developer mode by clicking 10 times build number, you will get developer mode in settings. go inside and use usb debugging on phone ask to trust. tick and ok open device manager. install moto drivers (download it is available on online) google you will find 3 or 4 unknown devices. click last one, go properties, update drivers. click manually and select comport type, select moto and add moto diagnostic dirvers you will find comport in device manager. open DFS, give spc for this phone spc is 000000 unless changed in programming go to mobile tab and change simple ip to pref mobile ip change total profiles one from 6 and active profile one. reset the phone and restart the phone. entered apn manually and saved APN settings are name=any apn is net, user name is net, password is net mcc is 404 and mcc is 00 that's all, phone works with RGE sim or RECRUC068 Correct me if any steps worng. 1 Share this post Link to post Share on other sites
moto_modx 1 Report post Posted April 30, 2016 Hello this XT1528 Switch off the phone. power it with vol down switch together use vol + or - to go to BPtools click power button. Phone powers, connect to pc. enable developer mode by clicking 10 times build number, you will get developer mode in settings. go inside and use usb debugging on phone ask to trust. tick and ok open device manager. install moto drivers (download it is available on online) google you will find 3 or 4 unknown devices. click last one, go properties, update drivers. click manually and select comport type, select moto and add moto diagnostic dirvers you will find comport in device manager. open DFS, give spc for this phone spc is 000000 unless changed in programming go to mobile tab and change simple ip to pref mobile ip change total profiles one from 6 and active profile one. reset the phone and restart the phone. entered apn manually and saved APN settings are name=any apn is net, user name is net, password is net mcc is 404 and mcc is 00 that's all, phone works with RGE sim or RECRUC068 Correct me if any steps worng. Hello This method is not working for me. After i change active profile to one. I clicked reset buttion in DFS and restarted the phone. however I do not get any option to add APN, it says APN is not available for this user. Please suggest what is missing here? thanks. Share this post Link to post Share on other sites
moto_modx 1 Report post Posted May 3, 2016 Hello Guru/Others, Can you anyone assist, if this method worked for any one? Regards, ritul Sonania Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted May 5, 2016 (edited) Xt 1528 Vzw moto E might be the first entry level CDMA smartphone from US having fully unlocked band 3, band 5 and band 40 with UE=GSM LTE. It shows all 4G bands active on various websites. Users can test and let us know. Sent from my K016 using Tapatalk Edited May 7, 2016 by dr.faramroze Share this post Link to post Share on other sites
atishj 8 Report post Posted May 6, 2016 This may be the first entry level CDMA smartphone from US having fully unlocked band 3, band 5 and band 40 with UE=GSM LTE. Users can test and let us know. Sent from my K016 using Tapatalk in xt1526, i tested but no success on jio 1800, 2300, idea 1800 LTE no Luck , Not Working--Shows Searching for Service. Hope any body test on Xt1528 any update result..... Share this post Link to post Share on other sites
inam 9 Report post Posted May 6, 2016 This may be the first entry level CDMA smartphone from US having fully unlocked band 3, band 5 and band 40 with UE=GSM LTE. Users can test and let us know. Sent from my K016 using Tapatalk I have tried this long back. Enabled the band 40 in DFS. But the Airtel 4G sim could not catch the 4G signal, only 2G. Is kernel or other modification required to enable the band 40? Share this post Link to post Share on other sites
sbaji52 8 Report post Posted May 6, 2016 Xt1526 work on jio for band 5 850 only . Sent from my FL7008 using Tapatalk Share this post Link to post Share on other sites
moto_modx 1 Report post Posted May 8, 2016 This may be the first entry level CDMA smartphone from US having fully unlocked band 3, band 5 and band 40 with UE=GSM LTE. Users can test and let us know. Sent from my K016 using Tapatalk I have tried this long back. Enabled the band 40 in DFS. But the Airtel 4G sim could not catch the 4G signal, only 2G. Is kernel or other modification required to enable the band 40? As far as I know this phone does not support any of the 4G bands available in India, only hope that I have is 700MHz band which is still not in consideration by TRAI. Share this post Link to post Share on other sites
kenpet22 2 Report post Posted December 16, 2016 I got Verizon Moto E 2nd Gen for a Friend in Vadodara. The phone is CDMA/EVDO mode and not enabled in GSM mode. Where can he get RGE series micro SIM card so that he can get voice, text and 3G data service working on this device. Please help. Thank you. Share this post Link to post Share on other sites
