rnk55 1 Report post Posted August 20, 2015 I got lg g3 vigor ls885 sprint from usa. I made it ruim only with qpst. voice is working but no data. I have a working micro sim of reliance with working data and evdo as i checked it on lg g2 and moto maxx. i also tried to install Shortcut Master Lite, search APN n search field, with apn settings editor but the apn doesnt get saved and nothing happens.when i click on mobile data it says " unable to establish a wireless data connection". kindly help me out. Share this post Link to post Share on other sites
ankurcshah 112 Report post Posted August 20, 2015 It will work only with rge sim as far as I know but when I insert rge it doesn't recognize Sent from my Motorola Droid Turbo using Tapatalk Share this post Link to post Share on other sites
rnk55 1 Report post Posted August 21, 2015 It will work only with rge sim as far as I know but when I insert rge it doesn't recognize Sent from my Motorola Droid Turbo using Tapatalk It recognises the reliance sim.It makes and receives calls but there come no sign of data, no 1x or 3g simbol. only shows the signal bars. when i turns on mobile data there appears a triangle saying " unable to establish a wireless data connection". Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted September 16, 2015 Please follow the same programming procedure as the LG Tribute. It works on normal RECRUC SIM with data. 2 Share this post Link to post Share on other sites
rnk55 1 Report post Posted September 21, 2015 Kindly suggest me link for programming procedure as the LG Tribute. I didnt find any link to unlock lg tribute either. Share this post Link to post Share on other sites
ankurcshah 112 Report post Posted September 22, 2015 Kindly read through lg forum . Sent from my Motorola Droid Turbo using Tapatalk Share this post Link to post Share on other sites
atishj 8 Report post Posted September 23, 2015 Kindly suggest me link for programming procedure as the LG Tribute. I didnt find any link to unlock lg tribute either. Have you tired ,plz post result Share this post Link to post Share on other sites
rnk55 1 Report post Posted September 24, 2015 I has msl and made the mobile on ruim only but i guess its not going on mobile ip. any way around to make it on simple ip , I tried qpst but it doest get changed to simple ip, it maintaind mobile ip. Suggestions please Share this post Link to post Share on other sites
rnk55 1 Report post Posted September 24, 2015 Hey Rim fellows, its worked,,, yes activation massage is there but only have to on/off aeroplane mode for that. Am thankful to all the rim persons here who share there great knowledge here. thank a lots again.... Share this post Link to post Share on other sites
gpkumaran 21 Report post Posted March 14, 2016 @rnk55 bro, how did you make it work? Share this post Link to post Share on other sites
rnk55 1 Report post Posted March 19, 2016 LG Tribute method worked. 1 Share this post Link to post Share on other sites
gpkumaran 21 Report post Posted March 20, 2016 Thank you. Sad to say that dint work for my ate boost. Share this post Link to post Share on other sites
bukshet_mayur 9 Report post Posted March 22, 2016 Please can you share the link here Share this post Link to post Share on other sites
