huaweitrick
samsung grand max and imported phone root
rooting all android phone even bluestack too
everybody know various app that can root android phone
but this guide will help u to root and also u r able to use XPOSED too
this will help u to root and install
super su instead of kingroot
1) why super su ????
bcz in kingroot many app not work
like xposed imei changer and some root app too
ist install kingroot from given below link https://www.dropbox.com/s/49m6slz4cnqoyjt/Kingroot_V4.5.0.902.apk?dl=0
and install in ur phone
after that use wifi or mobile internet connection
than click on start root wait 3 to 5 minute according to ur internet connection .
it will root ur mobile
NOW STEP TO REMOVE KINGUSER FROM SUPERSU
SUPER SU IS FAR BETTER THAN CHINESE KINGUSER
2 ) now download this file from the link place in root of ur internal sd card
https://www.dropbox.com/s/xl6b8dgmqhtrbqi/Replace_Kinguser_with_SuperSU-v2.0.zip?dl=0
3) extract it in internal storage from
file explorer
4) now install terminal emulator app from play market
now open it
type su ( grant permission )
now type sh /sdcard/mrw/root.sh
now it will give some error like in image
but later it will open super su
click on install as normal than reboot
now after reboot update it
i had tried many phones from
and get successful root
almost 80 % mobile will be done from this method
if it worked for u
hit like button.
sent by :- huaweitrick02
