bhoodarmal
Moto E 2015 LTE XT1526 to work with Reliance CDMA
Anyone knows how we can make the phone work with Reliance CDMA Sim Card. I bought a Virgin Mobile phone from Walmart USA and now came to India trying to make it work on CDMA. Though Virgin gave CDMA LTE network on USA but I unlocked bootloader and installed custom ROM to make it work on GSM network in Germany while I was on way to India and stayed in Germany for a week. All went well with same Moto E working with Lebara GSM in Germany and then after reaching India I inserted my Reliance CDMA card but still now able to make it work. I will put in points what all I have done so far
Sprint has Boost & Virgin both with same ROM. So all mentioned ROM I installed was BOOST as no Stock ROM for virgin is available. Actually BOOST/VIRGIN both are same which I confirmed when I restarted phone and it showed the Virgin pop up software to activate phone.
1. I restored the Phone with Stock 5.1 (Surnia) ROM and inserted my old 2005 Reliance Simcard (manually cut) which showed network and did PRL Update, Profile Update, UICC unlock which went successful. Moto E 2nd Gen LTE manufactured after Feb 2015 have SIM lock which can be easily unlocked internationally when you on travel via UICC unlock method that allows you to use other SIM. Seems my phone is manufactured after that thus it showed all successful.
2. The only problem is when I dial any number the dialer flashes and nothing happens. It only allows *228 and the nice lady voice tell "My phone is already activated". I desperately want to see it working with phone calls.
3. I thought the problem is old 2005 SIM hence I bought new Reliance CDMA SIM (again manual cut as they din had Precut SIM). I again did *228 so this new SIM gets the Phone Number transferred as it was successful. It can also see the 3G symbol with exclamation on Network signal. I again tried the UICC, PRL & Profile Update but all failed with "Socket error" means no signal.
4. I thought latest Android 5.1 has issues hence I downloaded XT1526 Android 5.0.2 stock ROM from FILEFACTORY and tried but still the same dialer flash.
5. Some post suggested to get MSL code and unlock using the ##3282# -> EVDO -> DDTM to turn off which requires MSL/SPC code. I tried all possible ways on Internet and used MSL Reader, Installed SU and used Terminal Emulater to run "getprop ril.MSL" but all returned blank with no MSL code. This made me confirmed that no MSL is there in my phone and this phone is manufactured after Feb 2015 which has Domestic SIM Unlock policy and is open for international travelers.
Can anyone suggest what I can do here to make Reliance CDMA network work with new Moto E 2nd Gen which I bought in Nov 2015.
*#4636*#*# -> Phone Information -> Set Preferred Network Type -> Has All Frequencies available.
In 2005 Sim it showed Network Type: 1xRTT
In 2015 New Sim it shows Network Type: EvDO-rev.A
Please provide me the way out.
Hey Guys,
I made it work but still looking in the data aspect of Reliance on XT1526
So here is the story for Moto E 2nd Gen CDMA/LTE XT1526 (codename: Surnia, https://en.wikipedia.org/wiki/Moto_E_%282nd_generation%29#Hardware) bought from Virgin USA to be used with India Reliance CDMA. I hear that Reliance works out of box for many Verizon customers and Sprint Boost customer but mine did and it is specifically for customers having Virgin Moto E 2 nd Gen CDMA/LTE.
I tried almost 2 weeks to make the Reliance CDMA work but only Indian GSM providers (Airtel) were working via Custom/stock room after rooting the phone. I faced issue with Reliance CDMA, were call dialing flashes while making call and nothing happens. It was just allowing me to dial *228 which goes through dialing procedure and connects with Reliance automated IVR that's says your phone is successfully activated (which is already active thought based in SIM)
Note: This process is tested on my Moto E 2nd Gen and I am not responsible for any issue happening after following this method. Try this on you own luck. Also, this test was done on new replaced Reliance SIMCARD (OMH - nonprecut) because old SIM was not tested on below Cynogen Method. If you have old Reliance SIM, you can try these steps first and then change the SIM, if it doesn’t work. Though I was not able to make data working in this new SIM as well that needs some investigation.
Steps to Root and make Moto E 2nd Gen 2015 (Surnia) work on Reliance CDMA
  1. Install ADB, Fastboot from google and Drivers for your Moto E from Motorola website (https://motorola-mobility-en-in.custhelp.com/app/answers/detail/a_id/89881/action/auth)
  2. Unlock the bootloader of your Moto E 2nd Gen. (https://motorola-global-portal.custhelp.com/app/standalone/bootloader/unlock-your-device-a)
  3. Download TEAMWIN recovery image surnia_twrp_2870.img (https://www.androidfilehost.com/?fid=24052804347765335)
  4. Download CynogenMod latest/stable build 12.1 (Not recovery as you have twrp) (https://download.cyanogenmod.org/?device=surnia&type=)
  5. Downloaded GAPPS - Google application Bundle for ARM Platform not ARM64 (http://opengapps.org/?api=5.1&variant=stock) . Moto E 2nd Gen uses Qualcomm Snapdragon 410 (https://www.qualcomm.com/products/snapdragon/processors/410) which is 4x ARM® Cortex™ A53 1.2 GHz quad-core thus chose ARM not ARM64.
  6. Backup your phone data, copy CynogenMod & GAPPS ZIP on phone SDcard and turn off the phone.
  7. Boot phone to bootloader by pressing all 3 buttons on right side of phone (Power + Vol Up + Vol Down).
  8. Connect you USB cable to Laptop while on Bootloader screen. Open the ADB, FASTBOOT folder and Shift+Right Click to get "Open Command Window Here".
  9. Copy surnia_twrp_2870.img in same ADB folder and run command
> fastbook devices (It will show some digits which means your device is recognized & connected)
> fastboot flash recovery surnia_twrp_2870 (This will show few status update and done)
  1. Now reboot the phone back to bootloader using step 7 and choose recovery using vol down button and press Power button to open TEAMWIN recovery software.
  2. While browsing through TWPR, it might say your phone is not rooted, do you want to continue. Please continue to root it. It might say later also while you trying to reboot phone hence do it as rooting is necessary.
  3. From TWPR, Click Wipe -> Advanced Wipe. You will find Dalvik Cache, System, Data, Internal Storage, Cache, Micro SDcard, Android Secure, SD-Ext. Select all mentioned except your SDcard and "Swipe to Wipe" at bottom.
  4. Wipe should be saying successful on top. If not, do one by one and see which one is not getting successful.
  5. If there is an issue with any of the above partitions then it is not successful hence note down the message shown in logs.
  6. Message may say "E: Unable to mount '/data'" or "E: Unable to mount '/cache'" or "Ensure the partition listed below is the correct one: /dev/block/mmcblk0p43"
  7. Above messages are common and usually may occur when you try to downgrade the ROM like KitKat which tried to change File System Encrypted for Surnia Moto E. The latest Moto E 2015 has Flash-Friendly File System (F2FS) which might be using Solid-State Disks (SSD) or eMMC (https://en.wikipedia.org/wiki/F2FS). If message persists you need to check the Filesystem and change it using TWRP.
  8. To change Filesystem, on same "Select Partitions to Wipe" screen select SYSTEM and click "repair or Change file system", check "current file system" which may say ext3, ext4 or F2FS. Click "Change File System" button and change to EXT4 if it says F2FS or vice versa. Do it for all three - SYSTEM, DATA & CACHE and retry Step 12 to wipe all. <<Mine is running on EXT4 as I tried downgrading to Kitkat and got those mount message. I found encryption problem hence this step is necessary. You may try all with F2FS file system as well and see how it works>>
  9. I am pretty sure Wipe would be successful but if that doesn't happen jut reboot the phone back to TWPR and try "Swipe to Wipe" after checking File system intact.
  10. Go back one screen of TWPR and click Format Data. All the logs should be successful.
  11. After another reboot to TWPR click Install button and select (Up A Level) -> select external_sd -> select CM 12.1 rom and install. It will go through installation process. Once completed reboot your phone and here you have the Moto E 2nd Gen rooted with Reliance CDMA working. Make a call, send message, receive call and check. You would be happy :)
  12. Power off and boot to TWPR again to install Google Apps bundle if you want. Follow same Step 20 to install GAPPS which will take some time to install and optimize Apps.
Again, this is for Moto E 2nd Gen LTE/CDMA bought from Virgin Mobile in USA and mine did not work for CDMA Reliance phone out of box but had to follow above steps to finally make it work. I used custom ROM from Orion that’s made my GSM worked in Germany (Lebara Network) and India (Airtel Network) while I was on international travel but I could not get 3g/4G work on GSM. Also, I install Boost stock ROM and tried all options of Settings -> System Update -> Update PRL, Update Profile, Update UICC unlock but nothing seems to work as mentioned on https://help.ting.com/hc/en-us/articles/205422098-International-SIM-Unlock-for-Travel and also on Sprint International travel Guidelines to get Master subsidy code (MSL) & Domestic SIM Unlocking (DSU). I tried MSL with all ways mentioned on Google to get MSL code and unlock using the ##3282# -> EVDO -> DDTM to turn off which requires MSL/SPC code. I tried all possible ways on Internet and used MSL Reader, Installed SU and used Terminal Emulater to run "getprop ril.MSL" but all returned blank with no MSL code.
*#4636*#*# -> Phone Information -> Set Preferred Network Type -> Has All Frequencies available. (This Magic way to select Between GSM & CDMA sim network and change the Network Settings accordingly)
Enjoy the Post and like it if this helps you.
Is there any way to remove the FRP on moto e . I got a phone from US where the previous owner did not remove his Google account and did a factory reset and shipped the phone to me, now post factory reset I am unable to log in . Post connecting to WiFi it asks for the user details of the previous synced account and does not proceed further .
Sent from my XT1031 using Tapatalk
There are some tools available on gsmhosting.com and a few tricks on YouTube. If you still cannot bypass gmail login, then a local repair guy having box software will do it.
Sent from my K016 using Tapatalk
Yep I tried all those and it did not work. Now need to find a local repair guy who can fix this in Bangalore
If you are OK with custom rom try cm12 , it will not ask for old G account. Also for boost there is stick debloted rom. Try it
I am ok with using custom rom even CM12. Challenge is how do i install the same as the phone is not rooted. I can't root the same as it is not in developer mode. Can't go into developer mode as it is asking for the google account username and password for the previous owner. Stuck in a catch 22 situation, I also checked as suggest by Dr faramroze, but did not get any local guy with a box, who can fix this issue.
Any suggestions are welcome, as i am stuck with a phone and desperately want to get this working.
Where r u in Bangalore?
Ping me on Hangout
Edited by ::Hitesh::
Dushie, I am sure you might have tried below links. It talks about bypass screen, forgot password account etc and if you are successful the you can enable USB debugging from options to install custom rom by rooting (Method written in second thread). It also tells how to enable it via ADB. These links may help you. Happy Rooting.
http://android.stackexchange.com/questions/112040/how-to-enable-usb-debugging-in-android-if-forgotten-pattern-for-screen-unlock
http://android.stackexchange.com/tags/locked-out/info
None of above is helpful as there was no way to enable USB Debugging,
But now I got it pass setup screen and rooted
AND its ready for new google account ! :surprise::hypocrite:
Hitesh bhai Thank you very much, You are awesome .No solution or option was available anywhere yet you were able to fix it.
Is this issue limited to Virgin Moto E XT1526? How about Sprint Moto E XT1526 version? does that work on Reliance out of the box?
Hi Kenpet22,
Yes, seems the issue is only with Virgin Moto E XT1526. Actually Virgin is subsidiary for Sprint and both have same code(Surnia) but Virgin contains no MSL/SPC. I have seen many post saying Sprint Moto E works out of box for Reliance but Virgin I did not see myself hence I had to go through all above procedure mentioned in my second post.
Yes Sprint Moto E does work out of box. I am using the same on Reliance CDMA sim post Hitesh Bhai fixed the FRP lock issue and it is working fine on the latest from.
Thank you for the feedback. Is there any particular OMH (open market handset) sim (series, etc.) to get EVDO data working on XT1526? Can you please provide that info please? Thank you.
Boost XT1526 does not detecting 4G idea Sim on WCDMA/GSM network, Normal Sim works can anybody help,??
Also can anybody help me to work IDEA Lte on XT1526??
Edited by atishj
Guys I keep getting this beep beep sound from my phone during the call and even after the call is over!!!
Anybody
Anybody
Just check your phone if some hidden call recorder is set. Beep Beep sound must be because the conversation is getting recorded either on your phone or the other side phone. There is a software "NoBeep" may fix or get your factory hard reset. If there is nothing like that then try factory reset or see a technician.
Guys
Does Verizon Moto E 2nd gen support EVDO Rev. B? ty
Nope. Only RevA.
Now,
will Xt1526 will work for RCOM/RJIO 4G 850 band or any4g band, or any way to work??
As CDMA will get Off
Edited by atishj
Even I am searching for the answer but my seller told me that chances are 50% I.E. for devices which are US based e.g. Sprint
Now,
Same question in my mind
But xt1526 supports band 850
Surely it will work
Sent from my MI 4W using Tapatalk
I think we will wait for full commercial launch. What I hear from Reliance store is that they are going to distribute the SIM from 25th Apr for existing cdma customers
Ping me on Hangout
Hitesh Bhai, can you please share the link to the ROM you had installed on my phone. Today some update came post installing that phone went into boot loop. I tried to fix the same in recovery options but it did not work and phone is not stuck on the logo screen. I am able to get into the recovery mode, need to know which rom to download and install on my Moto E.
