KanagaDeepan 1,084 Report post Posted May 6, 2016 Rel GSM not at all possible. But RJio possible with jio join app, using the band 5 LTE sent from my Lenovo Vibe P1 using Tapatalk Share this post Link to post Share on other sites
man-saturday 32 Report post Posted May 6, 2016 Lava X11 Specs >> http://www.lavamobiles.com/smartphones/x11 Best Price Rs 6749 >> http://www.ebay.in/itm/Lava-X11-crystal-blue-2GB-ram-Android-v5-1-OS-4G-with-VoLTE-5-GHz-Upgradable-v6-/281974640741?hash=item41a6ff9065:g:fVwAAOSw2ENW78j6 Supports all india LTE Bands 3, 5 & 40. VOLTE Support Android 5.1 with Guranteed Upgrade to Android Marshmallow Dual SIM 5"Display, Corning Gorilla Glass 2GB RAM, 8GB ROM, microSD upto 32GB Hi Rajan, It looks like the Lava X11 & the Xolo Era X are identical handsets. The Xolo is around 1200 cheaper. Maybe they are made by the same manufacturer? Check out the specs. Share this post Link to post Share on other sites
commonman 228 Report post Posted May 6, 2016 Lava and Xolo are brands owned by the same company. 1 Share this post Link to post Share on other sites
sraj68 5 Report post Posted May 7, 2016 I am using samsung galaxy s3 US CELLULAR for my CDMA connection. Do i have to change my handset? My phone's specification says it is 4G LTE. Kindly guide. Sent from my SCH-R530U using Tapatalk Share this post Link to post Share on other sites
magician_sayed 5 Report post Posted May 7, 2016 I am using samsung galaxy s3 US CELLULAR for my CDMA connection. Do i have to change my handset? My phone's specification says it is 4G LTE. Kindly guide. Sent from my SCH-R530U using Tapatalk There is no GSM radio in us cellular s3.and also no VOLTE Support Share this post Link to post Share on other sites
disney 13 Report post Posted May 8, 2016 In the handsets offered by paytm, Band 3 and Band 40 are common. so we can assume that whatever handset has both band 3 & 40 for LTE will work with RCOM 4G. RCOM_and _Jio_Spectrum_MR_18012016.pdfRCOM_and _Jio_Spectrum_MR_18012016.pdf Share this post Link to post Share on other sites
blueox 1 Report post Posted May 10, 2016 I am having a cdma handset samsung galaxy S3 ( Model SPH - L710 ) 4G LTE variant . please guide me that will it work on reliance 4g network upgraded sim. 1 Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted May 10, 2016 Cheapest smartphone to support all india LTE band 3, 5 & 40...Intex Cloud Fame at Rs 3,999 >> http://www.snapdeal.com/product/intex-cloud-fame-8gb-4g/669862773482Specs >> http://www.intex.in/mobile/smartphone/cloud-fame-4g/ Android Marshmallow 6.0 4.5" Display Gorilla Glass 3 1GB RAM, 8GB ROM Dual SIM Share this post Link to post Share on other sites
kk999 25 Report post Posted May 10, 2016 (edited) Xolo Black 2Gb will support Rcom 4g sim.... ??? Edited May 10, 2016 by kk999 Share this post Link to post Share on other sites
smartnsweet007 0 Report post Posted May 10, 2016 Hi. I am new to the Forum. I am using a Verizon Moto Droid Maxx and a Sprint HTC 626 and a LG Tribute. Will I be able to use any or all of the above handsets with the 4G simcards and will I be able to use 4G on the same. I think the Tribute is a CDMA only handset but on the Moto Max and the HTC 626 Gsm sims also work. Thanks in advance. Share this post Link to post Share on other sites
commonman 228 Report post Posted May 10, 2016 Xolo Black 2Gb will support Rcom 4g sim.... ??? If you mean Xolo Era X 2GB black then yes. Share this post Link to post Share on other sites
commonman 228 Report post Posted May 10, 2016 Cheapest smartphone to support all india LTE band 3, 5 & 40... Intex Cloud Fame at Rs 3,999 >> http://www.snapdeal.com/product/intex-cloud-fame-8gb-4g/669862773482 Specs >> http://www.intex.in/mobile/smartphone/cloud-fame-4g/ Android Marshmallow 6.0 4.5" Display Gorilla Glass 3 1GB RAM, 8GB ROM Dual SIM 1800 mAh sir? with 4G? Share this post Link to post Share on other sites
kk999 25 Report post Posted May 10, 2016 Xolo Black 2Gb will support Rcom 4g sim.... ???If you mean Xolo Era X 2GB black then yes.Xolo Black series... Just look Like same LYF EARTH 1 Reliance Jio... Share this post Link to post Share on other sites
commonman 228 Report post Posted May 10, 2016 (edited) Xolo Black 2Gb will support Rcom 4g sim.... ???If you mean Xolo Era X 2GB black then yes.Xolo Black series... Just look Like same LYF EARTH 1 Reliance Jio... Does not seem to have Band 5 and no mention of VoLTE http://www.xolo.in/Black/specifications.html Also UI is HIVE and not stock android Edited May 10, 2016 by commonman Share this post Link to post Share on other sites
Venkatagiri 53 Report post Posted May 12, 2016 LYF has launched two more phones Wind 4 and Flame2 Wind 4 https://www.mylyf.com/wind-4 Flame 2 https://www.mylyf.com/flame-2#section2 Share this post Link to post Share on other sites
Deepak Shankar 79 Report post Posted May 12, 2016 Wind4 seems decent for the price band Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
sraj68 5 Report post Posted May 19, 2016 On 5/7/2016 at 0:51 PM, sraj68 said: I am using samsung galaxy s3 US CELLULAR for my CDMA connection. Do i have to change my handset? My phone's specification says it is 4G LTE. Kindly guide. Sent from my SCH-R530U using Tapatalk Rcom Still has not given any specification for the HANDSETS? LOTS OF CONFUSION. Is anybody using SCH-R530U ( US CELLULAR SAMSUNG GALAXY S3) ? It is a CDMA 4G LTE phone. Share this post Link to post Share on other sites
dev_4_all 11 Report post Posted May 19, 2016 2 hours ago, sraj68 said: Rcom Still has not given any specification for the HANDSETS? LOTS OF CONFUSION. Is anybody using SCH-R530U ( US CELLULAR SAMSUNG GALAXY S3) ? It is a CDMA 4G LTE phone. There is a difference between cdma 4g phones and normal 4g phones U can use 4g sim only if the network selection has exclusive lte mode only and not cdma/lte mode Just pop a airtel 4g sim and check it yourself If airtel works in your handset then 4g will also work for you In my sprint phone when i put a airtel 4g sim it does show network but shows that phone is in international mode Share this post Link to post Share on other sites
Venkatagiri 53 Report post Posted May 20, 2016 ZTE plans manufacturing unit in India to introduce VoLTE smartphones. http://economictimes.indiatimes.com/tech/hardware/zte-plans-manufacturing-unit-in-india-to-introduce-volte-smartphones/articleshow/52352942.cms The interesting part in this article is that it mentions ZTE has supplied 6 lakh handsets to LYF. LYF is also sourcing from CK Telecom Wingtech Tinno Share this post Link to post Share on other sites
commonman 228 Report post Posted May 20, 2016 which LYF models are ZTE make? Share this post Link to post Share on other sites
ni0987 179 Report post Posted May 20, 2016 I am sure Lyf Flame 1 is manufactured by ZTE, thought its not mentioned anywhere officially. Share this post Link to post Share on other sites
Openyard 3 Report post Posted May 21, 2016 Do I have to get a 4G phone post migration to the 4G network, or will a regular GSM phone work as well? My main use is only calling and sms (nothing else). Plus, I don't really like Android smartphones (I've been a dumbphone user for several years, so prefer those for utility). I was happy with my CDMA phone but since we are compelled to move now, I simply want to retain my existing number but don't require the extras of 4G. Just calling and sms is my sole purpose. Will any GSM phone suffice in this scenario? Share this post Link to post Share on other sites
rajanmehta 4,056 Report post Posted May 21, 2016 Any GSM phone will work. 1 Share this post Link to post Share on other sites
commonman 228 Report post Posted May 21, 2016 2 hours ago, Openyard said: Do I have to get a 4G phone post migration to the 4G network, or will a regular GSM phone work as well? My main use is only calling and sms (nothing else). Plus, I don't really like Android smartphones (I've been a dumbphone user for several years, so prefer those for utility). I was happy with my CDMA phone but since we are compelled to move now, I simply want to retain my existing number but don't require the extras of 4G. Just calling and sms is my sole purpose. Will any GSM phone suffice in this scenario? Yes, even the basic handset would do, provided R-GSM has 2G network at your place. Share this post Link to post Share on other sites
mani2020 1 Report post Posted May 26, 2016 (edited) Dear All, I was using Samsung S6 Edge SM-G925P Sprint unlocked for Reliance CDMA with a special sim for data working. Recently after getting call from reliance, i like to upgrade to 4G service but then i have to switch to GSM operator Can anybody let me know is data will work on phone?? as previously it was working with special sim only. Waiting for you answer and help Edited May 26, 2016 by mani2020 Share this post Link to post Share on other sites
