mitulsoni22
Add LTE bands To samsung S5 for Relaince 4g
Hello frnds
Have just heard that we can add LTE bands to samsung s5, by flashing custom Rom and kernel
So we can add lte band 3,5,40 for Reliance jio and use 4g on the same handset rather than changing handset
Just passed through this site and for to know
http://forum.xda-developers.com/galaxy-s5/general/how-to-add-rf-lte-frequency-bands-to-t2886059
Had ny1 tried or any idea regarding this thing.
Thank you.
You can add bands but phone firmware will not allow for work band
End of the day, even if this is JIO ready, you need the JIO join app for voice to work, from what I've last heard. Will that allow calls to non Jio-join app contacts???
Sent from my A0001 using Tapatalk
Hmmm lets c..let the 4g start working properly. Than will give a try and see.
Jio join is more of a dialer like application which routs voice on data. So if one doesn't have VoLTE handset, jio join will allow voice services on LTE connection
^^^ But can you then call anyone? Or only 'Jio Join' app users, on the lines of Viber & WhatsApp?
Yes, I have similar doubts.. Whether call wait, call forward works on Jio Join or not? Whether the "Jio Join" call disconnects when another call comes via 2G on another SIM?? But it can make offnet calls, but NOT so sure...
i got jio 4g without doing anything on Verizon S5 on rooted stock rom
Edited by ananth001
r u sure..as i hav a s5 verizon..but not even getting ny network....fget jio
by using JIO JOIN APP on non LYF phones, you can call any phone in india.  Provided you are not using Preview invitee SIM
Edited by Guru Gopal
In order to use the reliance 4g on my sprint note 4
I am trying to use my airtel 4g the phone goes in international mode and no data
Is there any way we can have lte only setting so that i can use sprint phone for reliance 4g
you can enable required bands via dfs/qxdm but on sprint phone it won't work, by default sprint doesnt have network parameters for band 40 and band 3.. instead it have parameters for 26 and 41..nvitem for band 3, 40 arent active.
you can get those parameters from same variant which have band 40 and band 3.
again, sprint have network roaming policies which doesnt allow us to connect to 4g. so there is something call as policyman in every sprint phone, that too needed to be patched.
Nothing is impossible. Just highly unlikely..
Any progress in this matter so far? Now that 4g is up and most sprint +samsung phones dont work.
Sent from my SM-N910P using Tapatalk
I have already enabled lte band 1800mhz and disabled others using DFS, but no use.
u can also enable the bands using hidden service menu.
planning to switch to cm13 + custom kernel build to check
are u getting at least 3g in note 4?
Edited by ssr
Most if not all sprint phone support band 26 and hence band 5 as well. The best 4g signal for jio and only 4g signal for reliance 4g is on band 5.
I am using Rcom 4g on sprint note 5 without any issues.
Sent from my SM-N9208ZDV using Tapatalk
Just installed S7 global ROM on spint note4.
everything looks to be working and also I can switch to GSM/UMTS/LTE
check out:
Hi SSR,  can say that, this method is working with Rcom 4g and bio 4g sims on sprint note 4?
 karnataka circle, 4g will launch at Aug 1, only then i can validate my changes.:unsure:
But the w7 global ROM is gr8 upgrade from  my existing ROM.
Edited by ssr
