ACS
Tapatalk
When I get into someone's profile thru Tapatalk, the 'started by' section should ideally list out the threads started by them. Instead it gives a list of participated threads..
Don't know if this is a Tapatalk issue OR whether they aren't getting proper feed from our forum
Sent from my A0001 using Tapatalk
A strange problem on tapatalk for last one week. I can see the latest posts of rimweb in the list on the left, but when I click the respective topic, the last post is not seen.
Sent using Tapatalk
On my iPad I keep getting outdated update in progress notification every time I use tapatalk for rimweb
@ACS, @praveenwarrier @::: VA ::: I have upgraded Tapatalk to version 1.2.3now  which is compatible with IP.Board 4.1.12.1 - Can you check if you are still seeing the issue or not?
For example, pls have a look at the screenshot. In the selected topic, which is the last post?
Sent using Tapatalk
Sent using Tapatalk
Same issue
No Arun, its still the same. For eg. I just checked the profiles of both the above members & the 'started by' section still lists their participated threads
Tapatalk has finally released an update for IP.Board a couple of days and I have upgraded Tapatalk (1.2.5) along with IP.Board as well. Can you check if the previously reported issues are still there or not and let me know?
The selected topic does not show the last post on the right side.(expansion)
I face this strange pop up every time I open tapatalk b185f30b65a9bd71f7d580b27b6570be.jpg
