maniac8828
Handset suggestion 5 inch or below
Hello members,
Looking to replace my handset. Please provide your valuable suggestions to help me get a good one.
Requirements:
1. Screen size 5 inch or below.
2. Good battery life
3. RAM should be 2 gb or above
4. VoLTE (jio) would be preferred
5. Price no issue
Thanks in advance for your sugestions.
Lenovo Vibe P1m if volte is not a must. Upcoming Redmi3 has all the things you have asked, but not sure when it's coming...
sent from my Lenovo Vibe P1 using Tapatalk
Thanks, will check out the details. Was looking for volte so that it could be used with jio in future...
4 hours ago, Venkatagiri said:
If 1.5GB RAM is OK for you LG-K332 is the phone for you.
Look no further
http://www.lg.com/in/mobile-phones/lg-K332
Thanks, will check it out. Any idea if it is working with Jio? Anyone tried?
NOPE... Apart from lesser RAM, LG-K332 has cr@ppy FWVGA display, smallish 2125mAh battery, 8GB storage -- out of which ONLY 3.4GB is available to user.. If RAM can be compromised, better go for LYF Wind 4... The RAM is non-issue if you disable all the JIO Bloat...
You can check out Xolo Era X available at 5499 on Amazon.
8MP primary camera with flash, auto focus, HD recording, burst mode, audio note, smile detection, slow motion video capture, panorama, location capture and 5MP front facing camera with flash. 5-inch (12.7 centimeters) IPS Corning Gorilla Glass capacitive touchscreen with 720 x 1280 pixels resolution, 294 ppi pixel density and 16.7M color support. Android v5.1 Lollipop operating system (Upgradable to v6.0 Marshmallow) with Spreadtrum 1.5GHz ARM Cortex A-7 quad core processor, Mali 400 MP2 GPU, 2GB RAM, 8GB internal memory expandable up to 32GB and dual micro SIM (4G+4G) with VoLTE. 2500mAh lithium-ion battery.
Oh.. I would like to go for higher RAM..
Thanks. Will check out some reviews. Do you have any personal experience with the phone?
You mantion budget is not issue than go for mi5 its slite biger 5.2inch but very slim
Sent from my SM-G860P using Tapatalk
The Redmi 3s seems a great suggestion. Only 2 questions remain regarding its specifications:
1. Does it support VoLTE ?
2. Does it support Band 5 ?
No online content has so far confirmed theses. But if yes, then the phone will be a huge hit if introduced here in India.
I was looking for smaller size (better). I like the size of iphone 5s/se, but wasn't finding anything in small size. 5.2 is even bigger. But, if i don't find anything good then maybe mi5..
Yes, looked at the online reviews. Phone is good but to your point, it doesn't answer anything clearly..
Since redmi note 3, mi Max and mi5 all support volte as well as band 1,3,5,40, there is no reason for redmi3s to not support them, IMHO. Only issue is, we don't know when it's coming to India.
Swipe elite plus. However no volte.
Sent from my SM-N920P using Tapatalk
Hi Maniac8828,
Rimweb Member LTE4G has mentioned LAVA X11 in his post in this thread
LAVA X11 4G matches your requirement.Take a look
http://www.lavamobiles.com/smartphones/x11
Edited by alugobi
Gionee F103 Pro @11990 is also work with band 5 and VoLTE.
Oppo A37 also support Same.
Read that jio offer is being extended to iPhones. iPhone SE seems a good option now...
Using RJio in single SIM phone may not be wise as VoLTE may not be available when you need to call on emergency basis.
If Rjio network is available volte will be available
Sent from my SM-N9208ZDV using Tapatalk
Most of the time it does not connect
