anki_79
Honor Holly 2 Plus supports Rcom 4G
Just now, anki_79 said:
Started getting 4G on Holly Honor 2 Plus from today, location -- on roaming at Delhi , Speed test on testmy.net... can anybody advise how do i know on which band i'm getting this ?
On netvelocity, click on the '+' sign at the bottom right, then click on 'RF Information'. You'll see Band - 850 MHz or 1800 MHz or 2300 MHz as the case may be.
Read more at http://rtn.asia/t-t/20272/rcom-reliance-jio-joint-4g-network-tamil-nadu-kerala-karnataka#cjeD7YiyscAbq8rd.99
Netvelocity is available here:
those who don't know how to check band can download netvelocity enterprise https://jioappstore.jio.ril.com
All Delhi & Faridabad ... connection quite stable
Sent from my TIT-AL00 using Tapatalk
@anki_79 have u recharged any 4g pack?
I am also getting latched to 4g but no 4g speeds
I am getting 2g barely
I am having 2g data pack active
Pls confirm I am also honor holly 2 plus user
POSTPAID USER presently in Delhi on roaming , consistent & stable 4G speeds .
Band info not available on NET VELOCITY app ...is there any other way ?
Net velocity app shows band info for RJio network only...
sent from my Lenovo Vibe P1 using Tapatalk
@kanaganDeepan Ji how to know which band show for rcom
Sent from my SM-G860P using Tapatalk
For samsung phones, there is a way...
Hi
I am also at Faridabad but not able to latch on 4G RELIANCE, H+ is working, SIM already patched. Please guide what else can be done.
Regards
@caringlover if sim is not latch to 2g or 3g you are go for sim patched.
But if seem is latch to 2g and 3g then no need to patch the sim.
I informed that I am getting H+ I.e 3G data is working, what next to latch on 4G.
Regards
@caringlover  did you get a SMS similar to below , my 4G started working after the below message.
You dont need netvolocity app to show the mobile band
most handset have default number which can show this info. (including 2/3/4G bands)
Eg for samsung u need to dial *#0011#
Latching to 4g network in Gujarat but speeds are of 2g
Data balance is around 10 gb
Am I required to recharge any 4g data pack to access 4g data speeds
Pls confirm guys
Iam using honor holly 2 plus
Rcom confirms that it works on all BANDS.
