nickaustin
need help with iphone 5c hotspot
hi,
Original cdma postpaid customer, upgraded to ril 4g [not jio, its reliance 4g]
currently in gujarat using iphone 5c
4g data works after manual apn settings. but option for mobile hotspot disappears as soon as i switch to LTE [hot spot works in 2g mode, 3g not available in gujarat]
apple supports says to contact my carrier.[and you know how cc is in india]
any idea who can i contact regarding this problem? 198 cc support is worst then useless
any solutions without jailbreaking?
thank you.
Can you manually enter apn details in carrier settings?
You may have to add same apn for internet into Lte hotspot field.
On 19/7/2016 at 3:55 PM, nickaustin said:
hi,
thank you.
Are you able to connect and browse in LTE mode using your handset? (I mean data working in 4G mode)
If yes then try to reset APN settings.
You need to delete the default APN and re-enter Reliance APN which should be as follows:
APN: rcomnet
APN type: default
MCC: (see table below for value related to your circle)
MNC: (see table below for value related to your circle)
APN enable/disable (should be enabled)
Don't change anything else.
Reliance (RCom) Circle Wise MCC & MNC Codes
Telecom Circle                                                     MCC     MNC
Andhra Pradesh (including Telangana)...............405     01
Assam.................................................................404     09
Bihar (including Jharkhand)................................405     03
Chennai..............................................................405     04
Delhi Metro & NCR..............................................405     05
Gujarat................................................................405     06
Haryana..............................................................405     07
Himachal Pradesh...............................................405     08
Jammu & Kashmir................................................405     09
Karnataka...........................................................405     10
Kerala.................................................................405     11
Kolkata Metro......................................................405     12
Madhya Pradesh (including Chhattisgarh)..........405     14
Maharashtra (including Goa)..............................405     13
Mumbai Metro.....................................................405     15
North East...........................................................404     50
Odisha................................................................405     17
Punjab................................................................405     18
Rajasthan...........................................................405     19
Tamil Nadu..........................................................405     20
Uttar Pradesh East.............................................405     21
Uttar Pradesh West (including Uttarakhand)......405     22
West Bengal.......................................................405     23
Now save and enable this APN. Reboot your phone and now you’ll be able to connect to the internet & tether too.
Edited by LTE4G
