LTE4G
Is Jio tv on PC coming ??
The link below shows that Jio Play works in browser on Laptop. I tried but was not able to login. May be its still in beta testing.
http://dreamdth.com/Thread-Good-News-JIO-PLAY-good-news-now-you-can-stream-jio-play-on-your-laptop-or-desktop
Don't know if any body succeeded on PC but the blog shows working images.
Login page https://jioplay.in/jio/#/login?origReq=
Disclaimer:
Though the Who is info says the site belongs to Reliance but still Please verify the Authenticity of the site before putting your password (or change your password before & after trying). You can search yourself for Who is info of the site jioplay.in and check.
Edited by LTE4G
Disclaimer:
it used to work perfect earlier on IE only . I have watched Wimbledon on it . Now it gives username pwd error . Which i think is if you are logged in on any other jio play app with your jio id
the site is from Jio only and will make you install a patch to see the video
Thanks ! for update. I was little sceptical  as username and password were not working and 'Forgot your password?' was also disabled.
Edited by LTE4G
Works on PC....... using jio tv on bluestacks......
I am talking about the link (https://jioplay.in/jio/#/login?origReq=) which can run Jio tv directly on PC browser just by signing in. Not by the way of using Android emulator.
^ Getting "invalid username or password".
is the site still working?
Read the Quote below :
I'm using with chrome extension but it's a little bit inconvenient. Anyone tried it, please confirm
 I found this from bottom of the site. The contact email seems not to belong to jio
  Quote
For any queries and for reporting an issue, call jio care on 0288-4017777 (from any mobile/landline, chargeable as per normal call rates).
Jamnagar Township users can call through intercom on 17777. Call centre will be operational from 9:00 am to 11:00 pm.
You can also mail us with your queries and issues on jio.care@ril.com
Read the FAQs below (from latest JioTV app) - JioTV for PC / Laptop is coming soon.
Screenshot_2017-05-22-22-33-31-373_com_jio_jioplay_tv.thumb.png.a309449ad40945eb2745fc1b35f96a45.png
Edited by LTE4G
Could any body give me jio bar code to take a connection by porting
No barcode is required for porting your port code is good enough
