Sandeep Ch
Jio4Gvoice WiFi problem
Hi ! friends this is sandeep chidurala ! i am having a problem with jio4gvoice app which is when on the mobile data it is showing me online but when i switch to a wifi network it is automatically going to offline  ??? how can i fix it need sum help !!
Jio4GVoice will work if you are on Jio data connectivity (direct data on mobile or JioFi WiFi).
It does not work on other WiFi network. I did not test it on Jionet WiFi, so can't comment on this.
I am not able to use Rich Communication Services using Jio4gVoice app while making calls to another Jio no. I am using RN3 and my friend has LYF. I am not getting option like "prepare your call" . Any fix pls..
RN3 supports VoLTE by default so you will not be able to make calls using Jio4GVoice app since you can make HD Video & Voice calls directly from Dialler.
So can't use RCS on RN3 OR is the feature only available on non VoLTE phones with Jio4gVoice ? Even Jio guys are clueless.
