Sachil Sawhney 0 Report post Posted October 24, 2017 If I recharge JIO with two plans i.e 509 plan and 999 plans and use 5 GB data per day, will it first use 2 GB high speed data of 509 plan and then high speed data of 999 plan or vice versa? I asked this question with JIO support, and they say "it will be combined" but could not explain what is meant by "combined" and kept saying "bus dono plan add ho jayenge" and that does answer my question. Needless to say, JIO customer support is stupid and untrained Share this post Link to post Share on other sites
LTE4G 195 Report post Posted October 24, 2017 On 10/24/2017 at 10:40 AM, Sachil Sawhney said: If I recharge JIO with two plans i.e 509 plan and 999 plans and use 5 GB data per day, will it first use 2 GB high speed data of 509 plan and then high speed data of 999 plan or vice versa? I asked this question with JIO support, and they say "it will be combined" but could not explain what is meant by "combined" and kept saying "bus dono plan add ho jayenge" and that does answer my question. Needless to say, JIO customer support is stupid and untrained Whichever plan is activated first or which ever plan's data expires first (daily expiry) shall get activated first imho. Share this post Link to post Share on other sites
Sachil Sawhney 0 Report post Posted October 24, 2017 On 10/24/2017 at 1:53 PM, LTE4G said: Whichever plan is activated first or which ever plan's data expires first (daily expiry) shall get activated first imho. are you sure? anybody else who has multiple plans? Share this post Link to post Share on other sites
commonman 228 Report post Posted October 24, 2017 Two plans will not work simultaneously. First plan will be active and second one will be queued for activation after expiry of first plan. Share this post Link to post Share on other sites
LTE4G 195 Report post Posted October 25, 2017 On 10/24/2017 at 8:15 PM, commonman said: Two plans will not work simultaneously. First plan will be active and second one will be queued for activation after expiry of first plan. Yes! You are right, but he is asking if he forcefully activates (using activate button in MyJio app) two plans parallel to avail 5GB per day. Share this post Link to post Share on other sites
commonman 228 Report post Posted October 25, 2017 Would the earlier plan not get forfeited in case of force activation? Share this post Link to post Share on other sites
Sachil Sawhney 0 Report post Posted October 25, 2017 On 10/25/2017 at 5:25 AM, commonman said: Would the earlier plan not get forfeited in case of force activation? i don't think so. since my last plan expired, i activated two 509 plans and both are active. This way i get 4 gb data per day for 49 days which is 196 gb of data. This is even better than 999 plan. but i can only confirm this in few days to see if both plans data is being consumed. but why this plan falls in monthly plan list when validity is 49 days? any ideas? Share this post Link to post Share on other sites
LTE4G 195 Report post Posted October 25, 2017 (edited) On 10/25/2017 at 5:25 AM, commonman said: Would the earlier plan not get forfeited in case of force activation? I have used this (forced activation) and saw that both plans remain active and the data of second plan comes in place when the data of the first plan gets expired for the day & booster pack thereafter. So in case of 509 & 999 the 2GB / day should get activated first & 999 should act as booster beyond 2GB. Good option from Jio. Edited October 25, 2017 by LTE4G Share this post Link to post Share on other sites
Sachil Sawhney 0 Report post Posted October 25, 2017 On 10/25/2017 at 9:36 AM, LTE4G said: I have used this (forced activation) and saw that both plans remain active and the data of second plan comes in place when the data of the first plan gets expired for the day & booster pack thereafter. So in case of 509 & 999 the 2GB / day should get activated first & 999 should act as booster beyond 2GB. Good option from Jio. but why 509 plan falls in monthly plan list when validity is 49 days? when should i renew it? Share this post Link to post Share on other sites
LTE4G 195 Report post Posted October 26, 2017 On 10/25/2017 at 10:24 AM, Sachil Sawhney said: but why 509 plan falls in monthly plan list when validity is 49 days? when should i renew it? Where is it mentioned as monthly plan? ₹509 (Pre-paid) provides 2GB/day for 49days (98 GB). Share this post Link to post Share on other sites
Sachil Sawhney 0 Report post Posted October 26, 2017 On 10/26/2017 at 4:02 PM, LTE4G said: Where is it mentioned as monthly plan? ₹509 (Pre-paid) provides 2GB/day for 49days (98 GB). This 509 plan shows under monthly category when you try to recharge on desktop computer Share this post Link to post Share on other sites
Sachil Sawhney 0 Report post Posted October 26, 2017 On 10/26/2017 at 4:02 PM, LTE4G said: Where is it mentioned as monthly plan? ₹509 (Pre-paid) provides 2GB/day for 49days (98 GB). but i like this double recharge. I am getting around 120 GB per month for only 624 rupees . both are now working side by side Share this post Link to post Share on other sites
LTE4G 195 Report post Posted October 26, 2017 On 10/26/2017 at 4:34 PM, Sachil Sawhney said: but i like this double recharge. I am getting around 120 GB per month for only 624 rupees . both are now working side by side Yes! this type of combination is only possible in Jio which allows parallel activation of plans. Share this post Link to post Share on other sites
MVP 3 Report post Posted October 30, 2017 (edited) On 10/26/2017 at 4:34 PM, Sachil Sawhney said: but i like this double recharge. I am getting around 120 GB per month for only 624 rupees . both are now working side by side Can you please post the breakdown of Rs 624 for 120 GB? Also, the 509 plan has to be activated before the 999 plan? If that is the case, what happens when your 509 plan expires before the 999 plan on the 49 the day? Then the next first active package will be 999 and if you recharge for another 509, then the daily 2 GB will come into effect only after the expiry of the remaining data of 999 plan? Nevermind, I thought you had recharged a 509 with 999. Edited October 30, 2017 by MVP Share this post Link to post Share on other sites
